Go to Post I quickly realized that, "hey, I'm looking at a wonderful piece of technology that defies gravity" and I calmed down quite a bit. - Elgin Clock [more]
Unread 11-01-2016, 00:41
Re: Robot intentionally tipping over
Originally Posted by Chak View Post
I find it hard to believe that a referee will allow a robot to have sideways bumpers in a match. I believe bumpers were intended to protect the world from the robot and the robot from the world. Having the bumpers sideways like that would be unsafe imo. You may not even pass inspection if you intend to do this as part of the robot design.
But if you have a way to move your bumpers down... that looks so complicated, it's probably not worth it though imo.
I think it COULD [Edit: NOT] be done, legally.
BUT, it's way way way too risky. You'd have to have two full sets of bumpers, one permanently mounted in each configuration. AND you'd have to be <120" perimeter in BOTH orientations. Not to mention having the ability to retract wheels for the start of the match. (And I'd use that within the match, too.)
An articulated Frame Perimeter is specifically banned.
It ain't worth it.
EDIT: I realized the problem here. The post-flop set has to be OUTSIDE the Frame Perimeter before the match, or the Frame Perimeter it's on is articulated. Either one of those is illegal.
Yep, illegal.
Unread 11-01-2016, 01:18
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Originally Posted by jkelleyrtp View Post
I know you aren't supposed to disseminate the rules from pictures but...
That picture has virtually nothing to do with this discussion.
A) It's referring the maximum height of the robot.
B) It's in reference to the robot being on a flat floor or not, not the orientation of the robot.
Please be careful not to post non-relevant information in these threads regarding rules questions. While nobody should take CD's opinion as a ruling, we must be careful to avoid spreading false information.
Unread 11-01-2016, 01:29
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud ofjkelleyrtp has much to be proud of
While I agree that this picture should be in no way an official ruling on anything, it was more to demonstrate the that whatever is considered the frame perimeter and extension changes with robot angle to the ground. If the top of that robot is 15" past it's own bumpers, then it would be illegal if considered an extension. Instead, it seems legal according to the rules, and that even a robot at an angle perpendicular to the ground satisfies the constraints. Thus to say that tipped robots might not contribute to extension size and perimeter limitations as mentioned earlier in the thread.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 11-01-2016, 03:32
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Originally Posted by John Retkowski View Post
Why would you want to tip over? If you mean tipping over to block a goal or a defense, I would consider those to be impeding the flow of the match.
A. intentionally tipping over
RI3D is intentionally tipping theirs over in the act of Scaling the Tower (more like an "L"), Tank Treads & Pullies out (like saying at the end of each match....Here you knave, now kiss the soles of my robot), in the attempt of blocking their opponents from scoring the win by Capturing the Tower and the points.
Unread 11-01-2016, 03:45
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Which Ri3D team? I want to see this.
Unread 11-01-2016, 03:55
FRC #0060
https://www.youtube.com/watch?v=gaGnaYYfiB8
The above addy gets you to the Ri3D youtube channel....Watch the Day 2 Stream 2 (or scan through until you see them gather around for the scaling test).....Of course they don't yet have any front or rear frame members on that AM Tank Drive or Bumpers on it yet so it is very hard to tell when it is hanging in the "L" position whether it is officially outside of the frame more than 15" or not. But they have it driving, collecting, shooting, and hanging. (The start of scaling test is around 2:52:10, full hang at 3:01 or so). That vid is 6 hrs. + long).
Hmmm, run that video out to the last 10 minutes and you will see the bot in shooter mode in front of the Defense Ramp (Either all the builders are midgets/dwarves, or that bot is well over the 4'-6" in height and would be illegal on field in this years game outside of the last 20 seconds of a match (no robot can exceed that height until then correct?)
Unread 11-01-2016, 04:51
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
I remember the oddest robot that ever made it to Einstein was 1218 in 2004. To get up onto the platform it would lay down on ti's side and drag itself up onto the platform. You can see it start to do it in the first semifinal match.. FIRST was very different back then . No more two team alliances. No more wedge bots. And bumpers exist now so these bots wouldn't be as effective.
Unread 11-01-2016, 05:17
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
I believe it would be the Robot Inspectors that would have the problem, and not the Referees.
The second set of bumpers would be outside the bumper zone, and thus not "Bumpers". You would have to design it so that the 2nd set of bumpers were:
1) Entirely inside the Frame Perimeter; and
2) Within the 120# weight limit.
Unread 11-01-2016, 06:44
DonShaw DonShaw is offline
FRC #1261
DonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of lightDonShaw is a glorious beacon of light
I believe this strategy would be in conflict with 1.1 Message from Woodie Flowers Award Recipients.
"We want to know they are playing with integrity and not using strategies based on questionable behaviors."
Unread 11-01-2016, 08:38
I have to add to this discussion that your robot has to satisfy all rules not just certain rules. What comes to mind are those rules and definitions that discuss bumper zone, FRAME PERIMETER and dimensions, bumper mounting (covering all exterior vertices) and articulation. Depending on dimensions, I can see the possibility of changes in aperture that can still satisfy the rules.
Unread 11-01-2016, 10:20
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
The rule that picture is related to has nothing to do with the frame perimeter or extensions beyond it. It ONLY has to do with maximum robot height.
Unread 11-01-2016, 10:37
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
R22 says: BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained between two virtual horizontal planes, 4 in. above the floor and 12 in. above the floor, in reference to
the ROBOT standing normally on a flat floor.
What defines "normally"? Starting configuration? Average position during the match? Where the robot lands if you were to pick it up and set it down again? Waived in the last 20s?
On a similar note, do the frame perimeter extension rules (R3, Fig. 4.2) rotate with the frame? If so, it would (awkwardly) prevent teams from going vertical while extending an arm to the rung (even if the height rules are waived).
Clarifying how these rules affect orientation changes will have a huge effect on teams attempt to scale the tower.
Unread 11-01-2016, 10:41
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Usually when robots tip over [unintentionally] they aren't fouled for changing their orientation on the field, or having "sideways bumpers." just something to consider.
R22: BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained between two virtual horizontal planes, 4 in. above the floor and 12 in. above the floor, in reference to the ROBOT standing normally on a flat floor. BUMPERS do not have to be parallel to the floor.
This shown, I believe you can have sideways bumpers, as they do not have to be parallel with the ground; there are no rules stating that tipping changes any configuration of the robot. There is also no limit on horizontal extensions, so you can put wheels on that flick outside of the frame perimeter up to 15 inches, which you can fall onto. (Careful with those measurements though, as you still want to go under the lowbar)
I believe this is legal.
[edit: Also, remember that "normally on a flat floor" is simply how your bot sat during inspection, as "R" rules are primarily guaged as inspection rules. That being said, "normally" is in starting configuration, and also the bumper zone is applied to your robot in starting configuration. Your bumpers do not need to fall within the bumper zone after tipping. Literally speaking, there isn't even a penalty for violating R22 on the field.]
Unread 11-01-2016, 12:58
AKA: Brendan Simons
FRC #5406 (Celt-X)
Hmmm, so what would happen if a robot raised it's ground clearance during a match, such that the bumpers exited the bumper zone? This would pass the "starting configuration" test, but would not pass "when you put the robot on the ground" test.
[Edit: because this: http://www.chiefdelphi.com/forums/sh...readid=141442]
Unread 11-01-2016, 13:05
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
R23. Bumpers aren't allowed to articulate as Eric mentioned. Just wanted to cite the rule.
