Go to Post The rules are the rules, but if the rules get so ridiculous some of us may choose not to play anymore and that is the bigger shame. - Paul Copioli [more]
Unread 10-01-2016, 10:31
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Vision fun
Would anybody want me to make a simple vision program that detects the targets and will give info on them similar to what i did last year with the yellow totes? I know wpilib already has grip, but it does not seem polished and I do not think they are really focusing on it...The solution ideally run on either the driverstation computer or something such as a powerful coprocessor(odroid) maybe the roborio itself...discuss below, just thinking this could actually be VERY useful if you have a shooter...
(example output image)
Unread 10-01-2016, 16:56
iSpotix iSpotix is offline
FRC #4049
iSpotix is an unknown quantity at this point
Re: Vision fun
That'd be awesome. I'm just starting to learn opencv and vision. I'll take a look at your code for the totes.
Unread 10-01-2016, 21:15
Head programmer
Re: Vision fun
Alright, since somebody wants it I will open source it...I will make a post about it soon
Unread 10-01-2016, 21:32
Ozuru's Avatar
Ozuru Ozuru is offline
It's always the programmer's fault.
Ozuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to beholdOzuru is a splendid one to behold
Re: Vision fun
Definitely please do. The vision tracking I made last year was inspired by your project.
Unread 10-01-2016, 22:10
jfitz0807 jfitz0807 is offline
FRC #2877 (Ligerbots)
Team Role: Parent
jfitz0807 is an unknown quantity at this point
Re: Vision fun
We are looking into vision processing this year. We have some new team members who are interested in programming.
We use C++, but I suppose we can translate your java.
It looks like you are using Network Tables, so I guess this runs on the Drive Station laptop in which case presumably we can use it as is on the laptop.
Are there any issues with a java program and a C++ program communicating with each other through Network Tables?
Thanks.
Unread 10-01-2016, 23:21
Head programmer
Re: Vision fun
Thanks.
hmm lets see, you might be able to write your own in c++. Esentially it could be run anywhere, from the driverstation (fastest computer you really have acess too) or a coprocessor) Network tables use a standard communication protocol so it will even work with labview.
Unread 11-01-2016, 01:01
Ozuru's Avatar
Re: Vision fun
Thanks.
Basically what Fague said. There is no reason that you can't easily port it over to C++. While there will be differences in the syntax, the process outlined will be the same.
Unread 11-01-2016, 01:50
Head programmer
Re: Vision fun
Originally Posted by Ozuru View Post
Basically what Fauge said. There is no reason that you can't easily port it over to C++. While there will be differences in the syntax, the process outlined will be the same.
in fact, there is even more documentation on c++...
your all going to hate me for doing this so easy, but here is a little sneak peek
the code isnt optimized nor does it really give any good details but hey, it identifies the targets
Unread 20-01-2016, 01:25
Head programmer
Re: Vision fun
Tower Tracker is live! click here for the link
