Go to Post I remember as a kid thinking how high a team number like 834 was. - Dancin103 [more]
Unread 10-01-2016, 12:27
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Does this chassis look as if it would work?
Originally Posted by MSOSDev View Post
A few other posts within this forum go into how Mecanum wheels would not be a good drive system type for this year's game. While we are considering pneumatic tires which are very likely to work, we are reluctant to lose the ability to strafe and quickly navigate the field. This is our current plan for our chassis which utilizes Mecanum wheels, and can be switched with the pneumatic tires at any time. This allows us to go to the competition with both sets of wheels and interchange them. The chassis has 6 inches of ground clearance. What is your opinion on the effectiveness of this chassis and drive system?
http://i.imgur.com/pJ9hPDj.png?1
Pneumatic wheels have so much grip that you'd probably couldn't turn with this base. But, with mecanums, you have no viable way of easily getting over the defenses without a separate mecanism. If you want to be able to use pneumatic wheels as a backup, you'll probably need a 6-wheel center drop.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 10-01-2016, 12:29
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
Could you explain what you mean by firing off the side?
I took it as meaning have your shooter face the left or right side of your drive train. That way there's no reason to need to strafe into the corner, just drive straight in up against the side of the field until you hit the wall the driver stations are on. That gets you into the corner with no fancy drive train, and a pretty simple manuver for your drivers.
http://team2168.org
Unread 10-01-2016, 13:21
FRC Warrior FRC Warrior is offline
FRC #4169
FRC Warrior is an unknown quantity at this point
We were looking to shoot from the corner of the opposing teams courtyard, that way you don't line up a shot every time. Just go to the corner, slide in sideways, put the shooter at a prefigured angle, fire, and get out. With normal wheels you'd have to back into the corner while turning. Even then you can't guarantee a snug fit every time.
Maybe use a turret?
Unread 10-01-2016, 13:52
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Here is our chassis crossing the 4" bump in 2012 with AndyMark 6" mecanum HD wheels. Worked fine on the real thing with a fully loaded robot.
https://youtu.be/jl8pHpCjQtY
There were deflector plates at 45 degrees on both sides of the wheels that extended to about 2.5" above the ground. Our wheel modules were clam shells that surrounded the wheel, included the bearings, and mounted our toughbox nano gearboxes.
Unread 10-01-2016, 14:33
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Originally Posted by mrnoble View Post
Sigh. Okay. Because mecanum precludes you from crossing terrain, especially of the types which our robots must cross for this game. A mecanum drivebase will get stuck on the first obstacle.
This is not true, it makes it challenging but doesn't preclude you. There were plenty of robots who crossed the barrier in 2012 with mecanums, and that barrier was 4 inches tall by 6 inches wide.
Here are 4 videos of proof
Some use other mechanisms to help but they are still mecanum drive trains, and if they can cross the 2012 barrier, they can clear the Rockwall, and Moat easily. and honestly the Drawbridge, Portcullis, Sally Port, Ramparts, Chevalle de Frise, and Low Bar, have more to do with other parts of the robot then the mecanums themselves. So of the 9 obstacles mecanums can handle 8 of them with proper engineering, that isn't to bad.
Now I don't think mecanums are a good idea for different reasons but crossing the defenses isn't one of them.
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 10-01-2016, 15:14
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
I'm no expert at modular systems but yeah that looks like it will work. Just keep in mind extrusions shouldn't go down on that design they should be up to keep the clearance. I'm interested in knowing why you would want the interchangeability.
I'm personally hoping the reason why you want the interchangeability is some dope strategy...
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
So I got my jacket back, but it turns out the "W" in WPI doesn't stand for that steak sauce I can't pronounce.
Play is for kids this is serious...
Unread 10-01-2016, 20:16
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
We used big mecanum wheels during Breakaway...they did surprisingly well on those ramps. I think bigger ones could probably *manage* to get over most of the defenses.
However, we found out that even the impact of coming down off the Breakaway ramps eventually started bending the heck out of the roller support tabs, eventually jamming them. Later in the competition season a major pit task was fixing all the bent tabs....and at like 400 bucks for a set, we weren't in the position to have spares.
I think mecanums would eventually get wrecked in this game.
Jim Browne, EIT
Team 1058 - PVC Pirates
Unread 10-01-2016, 20:49
evanperryg's Avatar
AKA: Evan Grove
We used mecanums in 2010 as well. Only year we've ever done it. I wasn't on the team at the time, but we still have the chassis from our 2010 bot with wheels still attached, and they seem fine. This could have just been constant fixing, or we just got lucky. Either way, mecs offer little that another drivetrain can't offer you in this game, at the expense of being more likely to struggle with the defenses. A decent driver should be able to maneuver this field easily on a tank drive.
2013
2015
Unread 10-01-2016, 22:41
philso philso is offline
FRC #2587
Originally Posted by JesseK View Post
Mecanum - the biggest issue will be making sure the tabs don't get bent while crossing any of the platforms. It may be a good year to spend some weight on the Mecanum HD's from AM if you find the aluminum tabs bend or fatigue.
With the "rough terrain" and all the ramps, you are likely to bend the roller support tabs as Aur0r4 found. The team we were with in 2012 used the AM 8" Mecanums. If our robot ever touched the edge of one of the bridges when it was not straight on, even at low speed, it would bend some of those tabs. A jammed roller would cause the robot to drive erratically (normal and strafe). We got used to jacking the robot up between each and every match and having a crew of 4 people, each checking one wheel to make sure none of the rollers was jammed. If one was jammed, the bolt holding it on would have to be removed so that the tab could be twisted back "just right" using a pair of channel-lock pliers. This was not fun at all for the pit crew nor was it fun for the driver.
Unread 11-01-2016, 09:46
RaptorRobot1711 RaptorRobot1711 is offline
FRC #1711
RaptorRobot1711 is an unknown quantity at this point
It's no use being able to save time with mecanums if you get over the defenses into the opponents courtyard because you're using macanums
