Go to Post Don't give FIRST ideas...we like our 45 day build season. They can make it shorter. Never underestimate the power of the GDC. - Littleboy [more]
Unread 01-11-2016, 10:28 AM
aaronjeline aaronjeline is offline
Aaron
FRC #1719 (Umbrella Corporation)
aaronjeline is an unknown quantity at this point
Code loading issue
Is anyone else having issue getting robot code to start.
Robot was provisioned with the 2016 image, then loaded the JRE, then uploaded code. Code uploaded fine, with no errors.
On the driver station, the communication light turns on, but the robot code light never goes green. No errors have been presented, and there is nothing in the logs. The uploaded code is the example code provided by WPI.
We have tried connecting to the RoboRIO over the USB, and over ethernet (no radio)
The only place that I have deviated from the manual, is that the manual says to use 2014/imager.exe, and there was no 2014 folder. Instead I used 2015/imager.exe. I did install the most recent NI tools.
Any ideas?
