Go to Post I have some free time tonight (What?) - Brandon Martus [more]
Unread 11-01-2016, 09:57
jdaming jdaming is offline
jdaming is on a distinguished road
Re: Rookie Stratagy
Originally Posted by XaulZan11 View Post
The #1 thing a rookie or inexperienced team should do is build a strong 6 cim drive train
Is 6 CIM really required? Seems to me if the team had the ability to add a 3rd CIM they would be better off with a shifting gearbox or one that was geared down from the KOP
Unread 11-01-2016, 10:20
george.tan's Avatar
george.tan george.tan is offline
Raider Power!
AKA: George
FRC #3005 (RoboChargers)
george.tan is on a distinguished road
Re: Rookie Stratagy
I agree, you really don't need 6 CIM drivetrain. Shifters would be beneficial for BREACH cycle. Don't forget about auton points either!
Unread 11-01-2016, 10:46
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Rookie Stratagy
MCC: KOP Drive Train and an over-the-bumper roller claw.
Build: A claw that resembles a lot of 2011's robots, and the ability to make it fold out from the inside of the robot over the bumper. Mechanically, about 30 lbs using beefy components.
Code: Autonomous 'drive forward forward for 2 seconds after folding the claw out'. After that, normal teleop.
Strategy: After autonomous, dump the ball that the robot started with. Drive back under the low bar, then through the secret passage, and play some massive defense. At 30 seconds remaining, make your way back to the opposing courtyard while finding a ball along the way. Use the low bar defense again. Go 'challenge' the tower and spit out the ball into the low goal while you're at it.
Value:
  • Autonomous crossing (10 points)
  • 1 ball delivered for a partner, or if they determine it's faster for you to low goal it then +2 points and another 1/8th of the weakened tower.
  • 25% of the breach using no additional time (5 points for the 2nd crossing; the first was done in autonomous)
  • 1 ball in the low goal (2 points)
  • 33% of a Capture
  • 1/8th of the requirement to weaken the tower
  • Challenge at the end (5 points)
  • Defense played for a 2/3 of the match, with no breaks in between. Oh btw, you can use your claw to dare your opponent to go get balls from your secret passage after you've placed them there...
22 points and major alliance contributions seem very reasonable to me - but there can only be one on an alliance...
GitHub
Unread 11-01-2016, 10:58
piersklein piersklein is offline
piersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the roughpiersklein is a jewel in the rough
Re: Rookie Stratagy
I think we are still all on our honeymoon phase here on CD. Remember last year when we said all the cans would be used in regional quals? And that the top 20 teams at every regional would be able to put up multiple 6 stacks every match?
What some people are describing here (a robot that can go over any obstacles and can score low goal) is not a MCC, its a top 5 seeded robot. A robot that can do those things is guaranteed at least 1 RP per match, 2 RPs with partners who can challenge, and all 4 RPs if any other robots on the alliance can score.
By themselves they would get:
15 Auto Points
45 Teleop Defense Points and 1 RP
14 Low Goal Points
5 Challenge Points
In a game where point values are quite low, this is incredible performance. If a robot can do all that by themselves, they are going to be a top seed unquestionably at a regional. Switch low goal with high and add a climber and you have an Einstein Finalist.
2016 Boston Semifinalists
2016 UMass Dartmouth Creativity Award, Quarterfinalist
2015 Northeastern Quarter Finalists (6th rank)
2015 UMass Dartmouth Winners
2014 RISM Rookie Inspiration Award, Semifinalists.
2014 NorthEastern Rookie All-star, Highest Rookie Seed, Semifinalists.
2014 NECMP- Highest Rookie Seed
Unread 11-01-2016, 11:09
philso philso is offline
FRC #2587
Re: Rookie Stratagy
Value:
  • 33% of a Capture
^ Yes!
With some intelligent planning, even a "low-resource team" should be able to bring the claw Jesse describes in the withholding allowance. A Helper Bot can always play defense and will always be more valuable than a Defense Bot and will be more likely to be chosen come Alliance Selection.
Unread 11-01-2016, 11:10
tmalecek tmalecek is offline
FRC #5822 (WolfByte)
Rookie Year: 2015
tmalecek is an unknown quantity at this point
Re: Rookie Stratagy
Rookie Team Reporting for Duty!
A question about the 6 CIMs comment...
Am I correct in stating that the current KOP Drive Base Chassis only includes a gearbox with input for 4 CIM motors (2 for each side)? If so, are there any gearboxes that mesh well with the KOP Drive Base that offer 6 CIMs? If 6 CIMs is not easily done using the KOP pieces, can't we achieve the same level of torque by sacrificing speed? Obviously you'd be a better defender with more pushing power, but you'd decrease your cycle time of delivering balls to the front lines.
We're also debating whether or not it's necessary to have a 2 speed option, so I'd appreciate any feedback about that. Any comments about how difficult that might be to implement (and keep in mind that we are rookies!)?
Thanks,
Tim
Unread 11-01-2016, 11:32
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: Rookie Stratagy
I'm not sure how much 6 CIMs will help you on the field, but I do know they will help you get selected as a 3rd robot. I've been on alliances where teams made our short list of 3rd robots just because they had 6 CIMs.
My previous post wasn't suggesting teams shouldn't be more than just a drivetrain that plays defense. I'm advising teams to not sacrifice their drive train or driver practice to add additional capabilities. Spending 5 weeks on a high goal scorer or climber while their drivetrain isn't reliable and drivers aren't practiced is a bad idea. Building a new, untested, articulated drivetrain (look back at some very good teams that struggled in 2010 due to fancy yet ineffective drivetrains) to weaken defenses instead of building a more simple tank drive is also a bad idea.
Unread 11-01-2016, 11:43
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Re: Rookie Stratagy
There are numerous veteran teams that should be paying attention to what's being posted in this thread.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 11-01-2016, 12:21
Re: Rookie Stratagy
Thanks,
Tim
Tim,
I was alluding to some of these things in my comment but was far too brief so let me elaborate.
KOP only allows for 4 CIMs as you pointed out. You would need something like:
3-CIM
3-CIM with Shifter
While these don't come with a Kit or anything to integrate into the KOP you can integrate them without a ton of trouble and a few teams can probably give you a step by step if you decide on that route.
You are correct that one of the easiest and most often overlooked changes that you can make is to change the ratio on the KOP gearbox. Andymark includes details on how to do this in the KOP assembly instructions. As mentioned it will be a power/speed tradeoff but blindly accepting the ratio that the KOP provides doesn't allow you to tailor things to the strategy you are trying to achieve.
I think putting teams on a short list because of 3 CIMs is silly. I have seen many 3 CIM robots be pushed around by a 2 CIM shifting gearbox just because of the ratios. Don't forget brownouts being a higher possibility with 3CIM drivetrains and everyone can agree that a robot dead on the field is a big red flag for alliance selection.
This doesn't mean that a shifting gearbox is within your capabilities as it will take pneumatics and some additional code to do it right. I know some rookies and a bunch of second year teams have been able to do this so it isn't out of the question.
I completely agree with Xaul in his comments about driver practice though. Getting a driver who is comfortable with the robot and who can control it well outweighs probably any of these changes.
I am curious how high ranking teams view a 3CIM drive vs shifting (or maybe neither of these is important)?
Unread 11-01-2016, 13:48
FRC #2587
Re: Rookie Stratagy
Thanks,
Tim
Yes, you can get the same torque by sacrificing speed. You then have the problem of catching the faster bot. You can't push what you can't catch. Adding a shifting gearbox adds complexity as jdaming discusses very well. It also adds a lot of cost. An effective driver will likely make more difference than two extra motors regardless of what role their robot plays. A good example is how 610's driver dealt with defense in 2013.
... My previous post wasn't suggesting teams shouldn't be more than just a drivetrain that plays defense. I'm advising teams to not sacrifice their drive train or driver practice to add additional capabilities. Spending 5 weeks on a high goal scorer or climber while their drivetrain isn't reliable and drivers aren't practiced is a bad idea.
With proper planning and design, it should be possible to start driver practice within the first few weeks of the build season. The mechanisms that give your robot additional capabilities can be installed later in the build season or be brought to your tournament in your withholding allowance.
Unread 11-01-2016, 13:52
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: Rookie Stratagy
Advice to rookie teams for Stronghold: Spend a lot of time perfecting a drivetrain that can traverse all of the terrain-based obstacles (not gates) including the low bar. If you are successful with this, you will make the playoffs at most events. The low bar will be a valued skill because it's consistently there (allowing for consistent alliance strategy) and it is very quick to traverse if you're low enough. If you perfect driving over obstacles, design a way to grab and release boulders. If you can do that we'll enough, you will be very successful.
