Go to Post Now the real question is where are corn dogs located on that list? That is truly all that matters. - Thad House [more]
Unread 11-01-2016, 14:39
origamitaco origamitaco is offline
FRC #4328
origamitaco is an unknown quantity at this point
2016 Java code not deploying
I have a demonstration tonight for STEM and the robot code will not deploy. Im using old 2015 code that I ported over to 2016 (all i had to do was change gyro to analoggyro) but it simply will not work. I have installed the update suite and updated the Eclipse plugins. Here is the output file
Buildfile: C:\Users\FuriousFalcons\workspace\Judy\build.xml
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory C:\Users\FuriousFalcons\workspace\Judy\build
   [delete] Deleting directory C:\Users\FuriousFalcons\workspace\Judy\dist
compile:
    [mkdir] Created dir: C:\Users\FuriousFalcons\workspace\Judy\build
     [echo] [athena-compile] Compiling src with classpath=C:\Users\FuriousFalcons/wpilib/java/current/lib/WPILib.jar:C:\Users\FuriousFalcons/wpilib/java/current/lib/NetworkTables.jar: to build
    [javac] Compiling 21 source files to C:\Users\FuriousFalcons\workspace\Judy\build
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: C:\Users\FuriousFalcons\workspace\Judy\dist
    [mkdir] Created dir: C:\Users\FuriousFalcons\workspace\Judy\build\jars
     [echo] [athena-jar] Copying jars from C:\Users\FuriousFalcons/wpilib/java/current/lib/WPILib.jar:C:\Users\FuriousFalcons/wpilib/java/current/lib/NetworkTables.jar: to build/jars.
     [copy] Copying 2 files to C:\Users\FuriousFalcons\workspace\Judy\build\jars
      [jar] Building jar: C:\Users\FuriousFalcons\workspace\Judy\dist\FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-4328-FRC.local
     [echo] roboRIO found via mDNS
dependencies:
     [echo] roboRIO image version validated
     [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only
  [sshexec] Connecting to roboRIO-4328-FRC.local:22
  [sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
     [echo] [athena-deploy] Copying code over.
      [scp] Connecting to roboRIO-4328-FRC.local:22
      [scp] done.
  [sshexec] cmd : killall -q netconsole-host || :
      [scp] done.
     [echo] [athena-deploy] Starting program.
  [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
  [sshexec] killall: lvrt: no process killed
  [sshexec] Remote command failed with exit status 1
  [sshexec] cmd : sync
BUILD SUCCESSFUL
Total time: 9 seconds
I have reimaged the RIO, reinstalled Java, switched batteries, everything. IPv4 settings are on automatic. I cannot figure this out. No errors in code. Sample code does not work either. Please help.
Unread 11-01-2016, 15:27
frcStuff's Avatar
frcStuff frcStuff is offline
フォスタ--
FRC #4268 (Beehive Robotics)
frcStuff is an unknown quantity at this point
Re: 2016 Java code not deploying
Maybe try setting the IPv4 settings to 10.XX.XX.5 where XXXX is your team's number. Like 10.43.28.5 for your team.
Unread 11-01-2016, 15:36
FRC #4328
Tried that. Same error. Driver station communicates with both scenarios.
FRC #4328
I'm looking to see if i can reflash the 2015 image and backport my code again. I can't find the image though.
Unread 11-01-2016, 15:47
frcStuff's Avatar
フォスタ--
I don't know if this will help or not but...
Unread 11-01-2016, 16:00
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Try deleting the bin, build, and dist directories for the project and then re-deploy.
2016 Curie Quarter-Finalist (5803, 3310, 2168, 5940), Lubbock Regional Winner (3310, 4063, 4301), Arkansas Regional Winner (16, 3310, 6055)
2015 Newton Quarter-Finalist (3130, 2468, 3310, 537), Lubbock Regional Winner (2468, 3310, 4799)
2014 Galileo Quarter-Finalist (2052, 70, 3310, 3360), Colorado Regional Winner (1138, 3310, 2543)
2013 Archimedes Semi-Finalist (126, 3310, 1756), Texas Robot Roundup Winner (3310, 624, 2848), Dallas Regional Winner (148, 3310, 4610)
2012 Dallas West Regional Winner (935, 3310, 4206)
Unread 11-01-2016, 16:48
FRC #4328
Reinstalled java and deleted those folders. Didn't work either. Any other suggestions?
Unread 11-01-2016, 19:03
FRC #4328
Frickin just realized I've got the wrong version of Java on the RIO. Used HardFP instead of SoftFP. Not near the robot right now, just browsing the instructions when I saw that. Will try tomorrow and report status
Unread 11-01-2016, 19:19
If that doesn't do anything, try enabling Warnings + Prints using the little gear in the DS Messages window or use RioLog in Eclipse. They may tell you your code is crashing and give you a clue why.
Unread 12-01-2016, 07:56
FRC #4328
I'm on my way to try what I posted previously but I have enabled those before and they kept giving me bad ping and that its switched to driver station mode, it would happen 4 times and stop. I'm assuming that was it crashing and starting because this year's image restarts on crash 4 times and then quits so that your not isn't dead on field from one lousy command.
Unread 12-01-2016, 11:13
FRC #4328
That was the issue. Fixed it with the correct version of java.
