Go to Post You do use CAD to prototype, Cardboard Aided Design. - Peter Matteson [more]
Unread 11-01-2016, 16:34
curtis0gj curtis0gj is offline
FRC #5033 (Beavertronics)
Rookie Year: 2015
curtis0gj will become famous soon enough
Exclamation Gyroscope Programming
Howdy fellow robotic enthusiasts. I am in dire need of assistance programming our teams gyroscope. I am working with the iterative robot template and I am trying to instantiate my gyroscope. However, I always get the error, "Cannot instantiate the type Gyro." I have read that it has to do with instantiating interfaces. But I am bad at programming so I am unsure about this. Please help.
Here is a glimpse of what I am trying to accomplish.
Gyro gyro = new Gyro(1);
Unread 11-01-2016, 17:15
Rookie Year: 2015
Re: Gyroscope Programming
I think I have solved the error last year it was, Gyro gyro = new Gyro(1); to instantiate. This year it seems to be, AnalogGyro gyro = new AnalogGyro(1); If someone could confirm this that would be awesome.
Unread 11-01-2016, 17:28
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Probably better to do `Gyro gyro = new AnalogGyro(1);`. You'll want to read up on interfaces and abstract classes.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Yes. See http://wpilib.screenstepslive.com/s/...e-2015-to-2016
Unread 13-01-2016, 00:17
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Why is it better?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 13-01-2016, 00:24
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
he doesnt mean its better, the Gyro class is simply a "template" to use so all 3000 teams that use gyros dont have to make their own classes...the class you are looking for is the analogGyro
Unread 13-01-2016, 14:03
Rookie Year: 2015
Does anyone know where I find an example of a PID controller that turns the robot 90 degrees using the gyro. I was looking at the examples that came with the robot java development plugin and I learned a bit from the potentiometer PID example but I couldn't figure out how to apply it to the gyro.
Unread 27-01-2016, 16:29
techkid86's Avatar
techkid86 techkid86 is offline
Magic Programer
FRC #3044 (0xBE4)
techkid86 is an unknown quantity at this point
To just turn 90 Deg, you just need to supply it to the PIDController where the encoder would normally go, as it is already a defined PID source. you would then use your drive motors as output. you would need to invert one motor, so that it turns, but that should be the extent if the mods. I'm not sure you need PID for this simple task though. It's likely easier to just stop after turning 90
"you can build a perfect machine out of imperfect parts" -Urza
