Go to Post Every year I develop new connections and greater friendships with FIRSTers - and every year I am surprised to find just how many amazing people there are here. - MysterE [more]
Unread 11-01-2016, 16:55
Jared Russell's Avatar
Taking a year (mostly) off
Re: Mismatched wheels
This only works as long as the difference in diameters of the driven wheels is very small. I've seen plenty of cases where a team achieved a 1/8"-3/16" center drop by having all axles in line and using a slightly larger custom center wheel(s) than on the corners.
A 1" difference in diameter is much larger than I would recommend for this purpose.
Unread 11-01-2016, 17:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
You'd kill your battery pretty quickly. Driving straight forward, the motors would have to provide enough torque to overcome the static or kinetic friction of the wheels you're slipping. Even without much weight on them, the outer wheels will take a decent amount of torque to slip like that.
I think the reason it works in the case of slight differences in diameter is because there's enough give in the carpet-tread system, that the tread and carpet just elastically deform to accommodate the differential as they roll from starting contact to full contact to releasing contact. The incoming tread and carpet is always undeformed, so it's not like there's any build up of differential. Elastically deforming the tread and carpet for that little bit still requires some force, but it's almost certainly less force than sliding friction.
Unread 11-01-2016, 17:20
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Agreed.
However, we've done this before, with a not-too-difficult proviso, that can make it work perfectly:
The trick is to change the belting / chain / gears (whatever it is that connects your center axle to the outer axles) so that the linear speed of the wheels is the same. This is a matter of adjusting the pulley / sprocket / gear sizes for the different-sized wheels. Essentially, you'll have a different reduction ratio to the 9" wheels than you would to the 8" wheels. In theory this is easy.
In reality, it's a little trickier (but not too much), in that you need to source (or make) pulley / sprocket / gear sizes that give the desired ratios. However, that's not an unsolvable problem.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
