Go to Post A pole is usually made of aluminum or steel pipe. You can get these wherever you get metal. :) As for polls, there's a check box in the "Additional Options" section of the New Thread page that you can click to create said poll. - Chris is me [more]
Unread 11-01-2016, 17:48
The Ginger's Avatar
The Ginger The Ginger is offline
#GingerPower
FRC #5464 (BluejacketRobotics)
Team Role: Driver
Rookie Year: 2015
The Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud of
G11 and G28 Technicalities
My team is woundering if camping a secret passage whlie your alliance scores 6+ goals would be legal. on one hand the opposing alliance doesnt HAVE to release the boulders ,but on the other hand you are kind of making them give you a boulder or risk getting a foul.
Unread 11-01-2016, 17:51
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Re: G11 and G28 technecalitys
You have to enter and exit from their courtyard, and you have to be extremely careful to not contact an opposing robot and draw a G21 penalty. Beyond that, there's no reason it wouldn't be legal.
Does anyone else remember when TBA signatures actually worked?
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
I believe that is absolutely legal. Just make sure you don't touch their robots or else you will get a tech foul.
Unread 11-01-2016, 17:55
FRANKlybored FRANKlybored is offline
FRANKlybored is a splendid one to beholdFRANKlybored is a splendid one to beholdFRANKlybored is a splendid one to beholdFRANKlybored is a splendid one to beholdFRANKlybored is a splendid one to beholdFRANKlybored is a splendid one to beholdFRANKlybored is a splendid one to behold
There seem to be so many woundering people on this forum. PLEASE, I repeat, PLEASE seek medical attention if you or anyone on your team is woundering.
Unread 11-01-2016, 17:56
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
An alliance has right-of-way in their own secret passage.
If you are blocking it and they want through, you need to get out of the way or take a tech-foul (G21)
G28 refers to the courtyard, not the passage. If you're in their passage during the final 20, they can hit you. And you'd get a foul.
2013-present: FRC Team 4276, Surf City Vikings
2011-2012: FRC Team 3677, The Don Bots
Unread 11-01-2016, 18:05
FRC #0840 (ART)
Says who? In my view that would be a violation of G11 on them.
Please refer to actual rules to support your viewpoints, not a general idea of how you think things should be. Not that you're the only offender...
Unread 11-01-2016, 18:20
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
G21 A ROBOT contacting carpet in the opponent’s SECRET PASSAGE may not contact opposing ROBOTS. Violation: TECH FOUL
If red team, in their own secret passage decides to use the secret passage to get to the neutral zone, they have that right. If on the way to the neutral zone they encounter a blue alliance member that is contacting the carpet of the red secret passage, that blue alliance member gets a technical foul.
THAT is the rule. I am sorry if I simplified that to "right-of-way" and caused confusion.
Also, I do understand G11.
Unread 11-01-2016, 18:22
The Ginger's Avatar
#GingerPower
Team Role: Driver
Rookie Year: 2015
We got 2 more ?'s on this subject. First, can u roll a boulder from your robot into the courtyard from the secret passage, or do you have to have possession of the boulder and personally take it into the courtyard yourself. or could u deflect it into the courtyard?
Unread 11-01-2016, 18:24
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
G40 A ROBOT may not cause a BOULDER to move from the NEUTRAL ZONE into the opponent’s
COURTYARD unless:
A. the ROBOT contacts the BOULDER within OUTER WORKS, and
B. the ROBOT completes its CROSSING (i.e. doesn’t completely back out of the OUTER WORKS into the NEUTRAL ZONE)
Unread 11-01-2016, 18:32
ASD20's Avatar
AKA: Andrew
COURTYARD unless:
I think he means transferring a boulder from the opponent's secret passage to the opponent's courtyard.
Unread 11-01-2016, 18:42
BenGuy's Avatar
BenGuy BenGuy is offline
Co-Driver - 3641 - Flying Toasters
AKA: Ben
FRC #3641 (The Flying Toasters)
Team Role: Operator
BenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of lightBenGuy is a glorious beacon of light
Wouldn't it be easy to draw a penalty if you are defending in your own zone. If someone is in your own secret passage and your were defending in your courtyard you could just go hit them and they would get a tech foul right? That seems like an easy way to draw penalties.
Ben Wolak
The Flying Toasters Website
Team YouTube
Team Twitter
The real problem with computers is that they do what you tell them to do, not what you want them to do.
Unread 11-01-2016, 18:58
FRC #0840 (ART)
No, that's not the rule. Please specify how "they have that right" or how the red alliance can contact the blue robot to cause a foul without violating G11.
Unread 11-01-2016, 19:03
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
G11 states that Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FIRST Robotics Competition and not allowed. Rule violations forced in this manner will not result in an assignment of a penalty to the targeted ALLIANCE.
Violation: FOUL. If egregious or repeated, YELLOW CARD
G21 states "a ROBOT contacting carpet in the opponent’s SECRET PASSAGE may not contact opposing ROBOTS." This is where the right is given to alliance members to have priority in their own secret passage. There is no discussion in the rule of who must engage contact. It simply says that opposing robots may not contact you in your own secret passage.
G11 is a rule that counters strategies, not other rules.
Unread 11-01-2016, 19:19
I'm going to make two statements here.
The first is that "Contact", when used as a verb, (very important) carries the implication that X is taking the action to make contact with Y. NOT the other way around.
The second is that a team that uses other rules to rack up penalties on their opponents is in fact using a strategy, and is in violation of G11. If there is a legitimate reason to take an action that causes an opponent to get a foul, then G11 wouldn't apply (most likely). If there is no legitimate reason, G11 applies. Whether or not G11 applies is going to be heavily context-dependent.
By the way, we've been discussing this in other threads since Kickoff. If 5-6 threads full of disagreement on one item isn't enough to ensure a change in TU#1, I don't know what is.
Unread 11-01-2016, 19:27
Even as a verb... "Formally stated, Newton's third law is: For every action, there is an equal and opposite reaction. The statement means that in every interaction, there is a pair of forces acting on the two interacting objects. The size of the forces on the first object equals the size of the force on the second object."
Thus, if I contact you, you contact me.
As for G11, it's to stop teams pulling strategies like blocking human player feeding stations and forcing them to have more than 6 balls within their castles.
Another good example would be if you pinned an opposing robot in your secret passage, and kept ramming him into a wall in order to keep fouling him. That would 1. Be bullying, and 2. Be totally illegal.
