KOP Chassis axle bolt issues...
We had two of our axle bolts that didn't fit through any of the bearings. The bearings measured to spec, but the bolts were oversized for the bearing whole by .008". Anyone else notice this? A quick trip to the flap wheel solved our issue but we had to remove a lot of plating for almost an inch past the threads.
Re: KOP Chassis axle bolt issues...
Had same problem on Saturday. Hit them a bit with a belt sander and problem was solved.
