Go to Post This [Coach badge] means no-touchy the controllers. Even to save them from certain doom. - Kevin Sevcik [more]
Unread 11-01-2016, 19:49
Unexas Unexas is offline
Lead Programmer
AKA: Douglas Byrd
FRC #3753 (BulahBots)
Unexas is just really niceUnexas is just really niceUnexas is just really niceUnexas is just really niceUnexas is just really nice
Re: Multiple Auto Modes?
Originally Posted by EDesbiens View Post
If someone needs help with having multiple autonomous modes on a Labview driver station, PM me We could discuss/skype about it...
I think i got it but if i run into any problems i will give you a call.
Unread 12-01-2016, 09:00
Tparbotmail Tparbotmail is offline
FRC #3944
Tparbotmail is an unknown quantity at this point
Last year we used a toggle switch which plugged into the DIO ports on the rio. we would flip the switch to run the code for that particular orientation on the field. This year we are going to work with an analog dial. However I'd love to try to incorporate this into the driver station.
Unread 12-01-2016, 09:22
Team34Guy's Avatar
Team34Guy Team34Guy is offline
Controls/Programming Mentor
AKA: Chris Southard
FRC #0034 (Rockets Team 34)
Team34Guy is a jewel in the roughTeam34Guy is a jewel in the roughTeam34Guy is a jewel in the rough
Why wouldn't your guys do it on the computer with a selector in the driver station? Way simpler and you can change the number of modes at any time...
There are multiple methods of doing this task. Our thinking was that with the changing field elements and changing start positions, it would be just as easy to set the switches when the robot was placed on the field. We've coded multiple routines in the past. It was just one of many options.
Unread 12-01-2016, 10:10
FRC #3944
I am always concerned about game day operation with respect to the use of the driver station software. If there was a bug, or the laptop got hung up it may cause a problem with operation. On the other hand the switches always work. It all depends on your comfort level.
Unread 12-01-2016, 11:19
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud ofAri423 has much to be proud of
In my three years I've programmed and driven with all three methods: switches on robot, physical switches on the control panel, and a virtual dashboard selector. Personally, I like physical switches on the control panel the best because you can set it really quickly (no need to fiddle around getting the cursor to the right spot) and you can make the change after you put your robot on the field (for last minute strategy changes). I know in 2014 we made last minute changes a number of times (to run or not to run) that we otherwise wouldn't have been able to make. But to each his own.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
Unread 12-01-2016, 11:34
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
What 2959 did is to create a scripting language. It is a pretty straight forward language that lets our drive team code a new auto on the fly. We have a couple dozen pre-written that we can load up, but it is pretty simple to code on the fly.
We tested it with our new programmers and after half an hour of instruction they were able to code a bot to go through a small maze an pick up a can at the end in about 1/2 an hour.
We extended it this year to allow for if then statements and functions, etc. We are hoping this gives us the edge during autonomous.
