Go to Post … it’s all good as long as the kids are inspired. - AdamT [more]
Unread 11-01-2016, 22:43
Professional Stat Padder
Re: What is a winning alliance going to look like?
Multiple different styles of winning alliances depending on the level of play and the regional they're at.
Some alliances will be 2 all-around robots and a defender or feeder, others will have specialists performing roles.
Hangs won't be necessary to win any event until at least after weeks 5.
(2015-Present)
Unread 11-01-2016, 23:26
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
This. After a few days of thinking on it I think most teams would be better served practicing to get 1-2 more cycles than wasting time with a scaling mechanism.
I see an alliance with 1-2 high goal bots and 1-2 low goal breachers/enforcers being the typical regional winning alliance. At least one regional will be won by an alliance with no high goal capability. Good luck winning if your alliance can't consistently breach and capture, those bonus points are worth a lot of cycles when your alliance has exhausted the defenses they can do easily.
Unread 11-01-2016, 23:46
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
I think the the winning alliance will be...
Excellent High Goal shooter "Spy bot"
Excellent Defense Damage bot
Specialty Bot
Specialty Bot sits at end of Secret passage (with ramp over lip) and Repeats the forward action of the Human player who bowls ball to the bot who intercepts and shoots the ball at High velocity to the "Spy bot" who is deadly accurate from that corner in the high goal.
That means 1 boulder in auto
Then another quick 5 using the HP to Special To High To Castle train after those six are scored against the castle any additional boulders get delivered or the special bot retrieves 2 boulders from field and shoot them to High Goal bot. Castle now weakened.
Special bot slides under low goal twice...then Scales
In the meantime breach has occurred and Damage bot Scales
Finally High Bot scales
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 12-01-2016, 11:14
NShep98's Avatar
NShep98 NShep98 is online now
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is on a distinguished road
You are looking at a G39 there:
G39 ROBOTS are prohibited from launching BOULDERS unless they are in contact with the opponent’s
TOWER or carpet in the opponent’s COURTYARD, and not in contact with any other carpet.
Violation: TECH FOUL per BOULDER
And note G40 as well:
G40
Actions such as “carrying”, “herding”, and “trapping” are not violations
of this rule.
A ROBOT may not cause a BOULDER to move from the NEUTRAL ZONE into the opponent’s
COURTYARD unless:
A. the ROBOT contacts the BOULDER within OUTER WORKS, and
B. the ROBOT completes its CROSSING (i.e. doesn’t completely back out of the OUTER
WORKS into the NEUTRAL ZONE)
Unread 12-01-2016, 15:29
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Either I'm misreading this or we're reading the rules very differently. Several rules conspire to specify that boulders have to be carried individually by robots through the outer defenses. Robots may not project boulders except from within the opponent's courtyard.
Edit: Above content Ninja'd by Nathan
I think there will be one sapper/breacher who also carries boulders in and can score many of them, and two boulder runners/scorers. At least two scale the tower. One of the robots switches to defense once the both the defenses and tower are weakened.
Unread 12-01-2016, 15:36
EricLeifermann's Avatar
EricLeifermann EricLeifermann is online now
Taking some personal time
Look to 2012 and 2010(not the passing in the zones, but the number of hangers) and I think the winning alliances will look like those.
2012-2016 Wave Robotics Team 2826
Unread 12-01-2016, 16:05
Noudvanbrunscho's Avatar
Noudvanbrunscho Noudvanbrunscho is offline
Scout mentor
FRC #4481
Noudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the roughNoudvanbrunscho is a jewel in the rough
I expect the number 1 robot would be a Breacher/High goal shooter.
The First pick would be a low bar Robot which does cycles from your secret passage (easy ball recieving) to the high or low goal (and mabye categorie B or D).
And for the Second pick i would choose a high defender.
preferably all climbers aswell
2015 - Team Spirit Award (Tesla-Archimedes Division)
2015 - Engineering Inspiration (Virginia)
2015 - Finalist (Virginia)
2014 - Imagery Award (Newton Division)
2014 - Engineering Inspiration (North-Carolina)
2013 - Rookie All-Star (North-Carolina)
Forty fooouuuuurrrr --- Eighty ooooooonnnnneeee!
Unread 12-01-2016, 16:08
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
I think the winning alliance will be a team of robots that can breach and capture. I don't know if doing both will be necessary with every regional but doing both is a good way to lock down the win or at least be in the running for the win. If two alliances can do that then it will come down to things like autonomous, high goal shots, and scaling.
2012 Dean's List Winner
2011-2014 Arizona Regional Winners
2016 Las Vegas Regional Winner
2014-? Mentor
Unread 11-01-2016, 23:36
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
I agree. With the number of points scaling is worth, it's not really a defining factor until you get to a stage where one high shot could be the difference between a win and a loss. This game is very unique in that no one objective is worth significantly more points than any other objective. (2015-cans, 2014-passing, 2013-climbing, 2012-balancing, and so on) Therefore, especially as the competition between teams gets closer, alliances' scores will get closer and closer to each other, until the ability to do something worth only average points, that (probably) requires its own separate mechanism, is absolutely necessary for success.
On the defense role:
"Defense bots," or robots that only defend, are (usually) not going to be a viable pick this season, even as a second pick. The only time a dedicated defender will be useful is on an alliance that doesn't rely on tower points, against an alliance who relies entirely on tower points. Especially at lower levels of play, where a breaching specialist alliance is viable, the role of the defender could be rendered largely useless. Yet, on the other hand, a capture specialist alliance is equally viable, and this would be the defender's time to shine. Therefore, a defense bot could be a game-changer in one series, then completely useless the next- that kind of situational quality is very risky, and without a backup bot to replace the defender in a situation where they're useless, it could mean the end of an alliance's run.
However, at medium-to-high levels of play, where both shooting and breaching becomes necessary for victory, the defense bot is now stuck between being pointless and being a great asset. On one hand, knocking a shooter off-angle during a shot could save your match. On the other hand, for how many points the defender prevents, it could be contributing just as much, if not more, by inbounding and getting balls to the enemy courtyard for its ally to score more conveniently. With the limits on possession, and the precision required for high shooting, a courtyard full of balls is your best friend if you're a shooter, and the defense bot could easily make that happen.
tl;dr: a "defense bot" is only useful in very, very specific situations, and often could be better utilized as an inbounder, breacher, or a combination of the two. We complain that last year's game had no defense, and GDC makes a game where defense is possible, but not strategically beneficial. Well played, GDC. Well played.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 11-01-2016, 23:53
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
While I often agree with you Kevin, any event just seems off. Hanging mechanisms will be the cheesecake flavor of the year IMO. If one robot on the alliance can climb in theory all 3 could with cake. 10 additional points is not a big advantage but 30 is. I would even go as far to say that climb points will be the winning margin at at least 5 regionals before week 5.
Unread 12-01-2016, 08:31
evanperryg's Avatar
AKA: Evan Grove
I can see climber cheesecakes being a thing, but I'll bet that at lower levels of play, collector cheesecakes will be the flavor of choice among tower-focused alliances.
2013
2015
Unread 12-01-2016, 12:19
tprize tprize is offline
Team Founder
FRC #5586 (Bond Brigade)
Rookie Year: 2015
tprize is an unknown quantity at this point
Alliance Captain - Shooting Bot
1st Pick - Breacher
2nd Pick - Assist Bot
I believe that there will only be one shooter with an assist bot because to have only one shooter that would not need to move and would be constantly fed ammo by the assist bot, this should allow the shooter to get off 33-66% more shots and should be more effective than having two shooters.
2016 Wisconsin Regional Creativity Award
2015 Wisconsin Regional Rookie All-Stars
2015 Curie Division Finalists (thank you teams 3663, 1574, and 2046)
2015 Curie-Carver Rookie All-Stars
Unread 12-01-2016, 12:36
Grayspecter Grayspecter is offline
AKA: Stephen Pang
no team (formally 1124 ÜberBots)
Grayspecter is an unknown quantity at this point
I think a winning alliance would probably consist of a cycling high goal shooter, a specialist breacher, and a secondary support/high goal shooter.
In autonomous, the cycling shooter and the support/shooter will attempt to cross the outer works and score in the high goal. The breacher will attempt to cross a defense and then cross back out to give it a head start in the breaching process.
During teleop:
The cycling high goal shooter (probably the alliance captain) would run cycles between the neutral zone and the opponent's courtyard through the entire match, passing primarily through Group B and D defenses.
A specialist breacher would spend part of their match running between the neutral zone and the opponent's courtyard a total of at least 6 times in order to damage the defenses for the minimum requirement for a breach (6 because the high goal shooter will be crossing defenses as part of its cycles). Optionally, if it is capable of going under the low bar, it can cycle two more times to net extra points.
The secondary high goal shooter would start their match as the defense robot in their own courtyard, harassing enemy shooters and blocking access to undamaged defenses (note: G25 states: "A single ROBOT blocking access to a particular DEFENSE is not considered impeding the flow of the MATCH."), as well as collected missed shots of opponents and placing them in the secret passage for access by the cycling high goal shooter. Personally, I think this role is crucial to an alliance, since with a limited amount of boulders on the field, it's important to maintain control of a slight majority of boulders at all times, so that high goal shooters can continue to shoot points throughout the match.
When the specialist breacher has finished satisfying the requirements for a breach, it will switch positions with the secondary high goal shooter, which will head towards the opponent's courtyard to shoot additional high goals. The breacher will continue to play the support/defense role of the secondary shooter until end game. At higher levels of play, this transition would be made more smoothly than in the beginning of the season, as breacher bots get more experienced and efficient at damaging defenses as fast as possible.
In the end game, they will at least capture the tower and most likely 2 out of the 3 will scale the tower.
Unread 12-01-2016, 16:33
Interesting thought actually. I never even thought about cheesecaking a hanger on another robot. I'm gonna go talk to my teams about this idea (although there are some obvious hurdles to overcome to do that).
However I still believe it won't be necessary to hang to win any event in weeks 0.5-4
The winning alliances will win because of their abilities breaching defenses and capturing towers more often than their ability to scale the tower.
(2015-Present)
