Go to Post I'm not gonna reinvent the wheel cause I can already buy it :) - Stephen Kowski [more]
Unread 11-01-2016, 22:49
sambino97 sambino97 is offline
FRC #3936
sambino97 is an unknown quantity at this point
Re: Grappling Hook?
Originally Posted by Ginger Power View Post
A grappling hook is a great idea, just not a grappling hook in the general sense... Maybe it could work, but I would hate to only have one try. Consider a spring/motorized arm with a detachable hook on the end of it. The hook would be attached to a winch that is mounted on the robot. Basically it's a grappling hook, but you're depositing the hook rather than treating it like a projectile. Something to think about...
I am not worried about only having one try. With the 20 second time limit, I don't think that you would have time to reload, launch, and lift after missing the first time. Plus a grappling hook could be very reliable if fired behind the bar and banked off of the angle at the bottom of the low goals.
Unread 11-01-2016, 22:53
GDB's Avatar
GDB GDB is offline
AKA: Garrett
FRC #2403 (Plasma Robotics)
GDB is a jewel in the roughGDB is a jewel in the roughGDB is a jewel in the rough
Re: Grappling Hook?
The funny thing is, our team started to joke around about this idea because we had a "grappling hook and winch system" in 2013, but as we went through the preliminary design process and started to design the prototype, it seemed more and more practical. I think it will be interesting what will happen this year with that though.
Unread 11-01-2016, 23:06
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Grappling Hook?
Originally Posted by rajkarthikkumar View Post
Is there anything in the rules that prevents a grappling hook from being used during the last 20 seconds?
We've played around with some grappling hook ideas for past games, although none have ever actually made it onto the robot. If you can, try finding someone from 1592, who designed grappling hook can pullers for last season. They were pretty cool. We may still have the CAD for some 3D printed claws that close on impact around a bar (basically, once the bar hits something inside the grasp of the open claw, the claw closes around the bar), if you might find that helpful I'd be happy to see if we can dig up the files and send them to you.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 12-01-2016, 01:06
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: Grappling Hook?
While that might be true, from a reliability perspective I'd take a hook on an arm vs a projectile any day. I'm not saying it won't work, because I think it would, plus it would be very cool to watch.
Unread 14-01-2016, 20:30
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Re: Grappling Hook?
This Sucks.
Q. G18 penalizes an extension more than 15" beyond the robot's frame perimeter. Is plane the measurement occurs in relative to the robot or the field? For instance, a robot uses a grappling hook to climb and tilts 90 degrees as it winches itself up. Do you do the same "virtually transposing the robot to a flat floor" as with R22 to determine if the hook extends greater than 15"?
A. Extensions outside the FRAME PERIMETER are measured in the same plane as the FRAME PERIMETER. As the FRAME PERIMETER is re-oriented (e.g. when a ROBOT drives up the BATTER), the plane of measurement is similarly re-oriented.
I really wish there was some flexibility there.
EDIT:
Smarter people than I can take a look at the geometry below. I used 2.5" to set the robot away from the tower. It seems to me that touching the tower directly behind the RUNG is a penalty as it is 15.7.." inches away.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
