Go to Post REMEMBER - there ARE things more important than robots... false - Botwoon [more]
Unread 11-01-2016, 22:34
chico_arduino's Avatar
chico_arduino chico_arduino is offline
AKA: Francisco
FRC #2576 (Chilean Heart)
chico_arduino is an unknown quantity at this point
Lightbulb Use of wheg?
what is your opinion about the use of a suitable weight wheg robot system for this challenge?
Unread 11-01-2016, 22:35
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Re: Use of wheg?
I'd be a little worried about the constant vertical height changes w.r.t. ball handling, but that's probably managable.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
Unread 11-01-2016, 22:41
Re: Use of wheg?
I would be highly concerned about field damage. You've got 150 lbf applying to 4-8 points with very small contact area, and a high chance of sharp edges. This would also be known as "spending a lot of quality time with the inspectors" as you show that no, it won't damage the carpet.
A tri-wheel might be better, or maybe some elastic stretched around would do the trick.
Unread 11-01-2016, 22:58
AKA: Ryan Zoeller
Re: Use of wheg?
I would think thick rubber tips would work, especially if they were feet which pivoted freely and laid flush with the floor. Although that greatly increases complexity. I'm also worried about the stresses on the bars themselves, but that's a different conversation.
FRC 2169 Alumni
Unread 11-01-2016, 23:02
AKA: Francisco
and a hybrid through the obstacle in wheg mode and then continue in the mode wheel?
and the tips can be round with rubber
Unread 11-01-2016, 23:04
AKA: Ryan Zoeller
Re: Use of wheg?
I feel like you are underestimating the fabrication difficulty of this situation, but maybe I'm missing something.
FRC 2169 Alumni
Unread 11-01-2016, 23:08
AKA: Francisco
Re: Use of wheg?
not at all, I just wanted to see what they think about the use of wheg system in this challenge, nothing more
Unread 12-01-2016, 08:49
dieDoktor dieDoktor is offline
AKA: Kipling Cohen
FRC #4118 (Roaring Riptides)
dieDoktor is an unknown quantity at this point
Re: Use of wheg?
I don't know fabricating would be so hard, if it has less curves that is, the hard part is actuating it so that it's "open" when you need it and "closed" when you don't.
Unread 12-01-2016, 09:01
Ryan Caldwell's Avatar
Ryan Caldwell Ryan Caldwell is offline
217 Alum, 2851 Founder, 469 Mentor
FRC #0469
Ryan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant futureRyan Caldwell has a brilliant future
Send a message via AIM to Ryan Caldwell
Re: Use of wheg?
This is a great idea for overcoming most of the defenses. I would caution maintaining a 3" bumper zone with the variation in ride height.
Our team used a unique drive design in 2010 to take on the large bump and didn't take into account the bumper zone which rendered our efforts useless during competition.
Insane and Insight are just about the same thing if you squint and turn your head ever so slightly
