Go to Post The GDC is becoming sane. - Zuelu562 [more]
Unread 11-01-2016, 22:24
Sperkowsky's Avatar
Sperkowsky Sperkowsky is online now
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Broaching Ends of Cylinders
Our team is looking at putting a cylinder on the end of a chain driven piece of 1/2 hex stock. That way we could position it at any angle.
What would be the easiest way to accomplish fixing a cylinder to a hex shaft. We have come up with 2 ideas.
1. Broach the bottom mounting hole.
2. Drill out the end mounting hole and weld in Competition robot parts roller end cap.
We do not have access to a welder or an arbor press/broach so neither of these are too easy. Welding is slightly easier as there is an auto repair shop across the street that can do it but they will most likely charge for it.
Are there any good strong cots solutions for this considering the cylinder is 36" long?
Thanks.
Unread 11-01-2016, 22:31
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
Re: Broaching Ends of Cylinders
You should reread the pnuematic rules because both broaching and welding the cylinder mounting hole is illegal.
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 11-01-2016, 22:32
We'll start by ruling out both 1 and 2 by R76--neither would be an allowed exception as nearly as I can tell. Pay close attention to R76C as it may give some ideas--like you might be able to build an end cap that would thread onto the cylinder's mount fitting, with a hole that allows a bolt to attach to the hex.
Unread 11-01-2016, 22:41
Sperkowsky's Avatar
Would that be something we could make with our limited resources? We have a water jet sponsor so could be getting get one cut and then thread the outside with a simple tap and die set?
Unread 11-01-2016, 22:48
Sort of. Actually, I think you could do it without a tap. Give me a couple of minutes and I'll see what kind of sketch I can come up with.
You'll have to put the dimensions on the attached item, but what I'm seeing is a custom clevis. The top (round hole) is sized in distance to lock the clevis to the cylinder's base. The hex is far enough back to allow the other side of the clevis to butt up against the base of the cylinder's mounting while maintaining strength.
This would be a two-operation setup on a waterjet that could handle thick material. Or with a machining sponsor.
The threading option would replace the upper hole, and require rather more drilling out of holes.
Name:	Block setup.jpg
Unread 11-01-2016, 23:08
Sperkowsky's Avatar
Thanks so much!
Unread 14-01-2016, 16:07
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Bimba and most other cylinder manufacturers offer hex mounting nuts. You could weld an adapter onto the nut then screw it onto the cylinder. Or use a taller nut with the same thread diameter/pitch.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
