Go to Post Understand the problem before trying to apply bandaids. You might not even be putting the bandaids in the right spot. - Bryan Herbst [more]
Unread 12-01-2016, 08:10
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
James Juncker will become famous soon enough
Re: Hanging Bar (Team Version)
Our team has the element built from hosting a kickoff event, I have personally tested the dowel rod with the same concern. I am glad to say that it was able to hold my 170 pounds for 3 pull ups (very scientific) but the dowel rod should be sturdy enough.
as for the dowel under the tower... I should be possible to combine the two it will just require more work to cut out sections of the tower/hanging bar.
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
