Go to Post The question is like asking "Is it better to drive by looking at a map the whole time or by remembering where you want to go and watching the road instead?" - lukevanoort [more]
Unread 12-01-2016, 01:19
Jay Burnett Jay Burnett is offline
FRC #5332 (Toaster Tech)
Jay Burnett is an unknown quantity at this point
What is the best center drop distance for an 8WD?
Hi CD,
My team is strongly considering using an 8wd this year, and we know that we need to drop the inner wheels some amount. We'd like to know what drop distance has worked the best in the past.
For reference, we plan on using 6 in or 5 in Colson wheels that are 2in wide.
Thanks!
Unread 12-01-2016, 01:22
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
Re: What is the best center drop distance for an 8WD?
On 6wd .150 is standard I believe
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 12-01-2016, 04:13
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
I usually design 8wd with a 1/8" center drop.
It isn't shiny enough.
Unread 12-01-2016, 06:38
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
I see the drop subject popping out quite bit this morning, are you actually making the center wheel lower than the ends one or higher where they don't actually touch the ground on a plane level?
Unread 12-01-2016, 08:12
I'm not exactly sure what the difference between those two options are. Could you explain?
Unread 12-01-2016, 08:24
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Having th e center wheels closer to the ground shortens the effective wheel base. You want the center wheels closer to the ground to make turning easier.
Unread 12-01-2016, 09:19
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Something else to consider is the spacing of the wheels horizontally. Most teams do not run the spacing equal between all the wheels.
Mentor 2415
Unread 15-01-2016, 10:07
LordTonyStark's Avatar
LordTonyStark LordTonyStark is offline
Co-Head Programmer/Wiring Captain
AKA: Thomas James
FRC #2929 (Jagbots)
LordTonyStark is an unknown quantity at this point
Our team is going to try to build an 8wd today, does anyone know the best way to fit 2 6" wheels and 2 4" wheels on each side? Does anyone have any photos of any 8wd on the chassis kit included with KoP? Thx
Unread 15-01-2016, 11:27
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Don't forget that you need different gear or sprocket sizes. If the wheels are in the ratio 4/6 then the ratios to those wheels has to follow the same ratio of 4/6.
If you have a 15:1 ratio from the motor to the 6" wheel you will need a 10:1 ratio from the motor to the 4" wheel.
Good luck.
Joe J.
Team #88, TJ2
