Go to Post Andymark has everything! - nighterfighter [more]
Unread 11-01-2016, 12:17
msonnier msonnier is offline
Engineering Mentor
FRC #2992 (SS Prometheus)
msonnier is an unknown quantity at this point
Scaling via jack up legs instead of "hanging"?
The definition of SCALE is as follows in GM:
"an act performed by a ROBOT, such that at the conclusion of the MATCH, it is fully supported by the TOWER, is in contact with at least one RUNG, and has all of its BUMPERS fully above the height of the low GOALS. (update in manual and fix “at least one RUNG”) "
Ignoring the note at the end with a correction -- that I suspect was supposed to be removed -- here is what I see as the key point that I want to inquire about:
-- It says you must be "in contact with" at least one rung -- does not say you must be supported
-- Says BUMBERS must be above the height of low goals
It seems to be you could perhaps build some "jack up" type legs into your robot which lifts the "frame perimeter" w/ the bumpers in addition to having some lightweight top appendage which "contacts" the rung. Maybe a lot easier then actually doing the pullup.
Google "jack up rig" and look at images for lots of examples in the oil industry of what I am talking about.
Here are some other potentially relevant rules:
From 3.1.4:
A ROBOT has SCALED the TOWER if, at the conclusion of the MATCH, the ROBOT:
A. is in contact with a unique RUNG, and
B. has all of its BUMPERS fully above the height of the low GOALS.
Blue box: The GOAL openings are not designed to be weight bearing surfaces.
Using these elements to SCALE the TOWER is not only in violation of
G12, but is also subject to an additional YELLOW CARD for egregious
ROBOT behavior as described in the final paragraph of Section 3.3.2
Penalty Assignment.
Here is the potential fly in the ointment:
R2 The ROBOT must have a FRAME PERIMETER, contained within the BUMPER ZONE, that is comprised of fixed, non-articulated structural elements of the ROBOT. Minor protrusions no greater than ¼ in. such as bolt heads, fastener ends, and rivets are not considered part of the FRAME PERIMETER.
R22 BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained between two virtual horizontal planes, 4 in. above the floor and 12 in. above the floor, in reference to the ROBOT standing normally on a flat floor. BUMPERS do not have to be parallel to the floor.
So here is the problem-- what does "standing normally on a flat floor" mean? In starting config the bumpers would be between 4 in and 12 in above the floor -- but when my "jack up legs" extend the robot is now jacked 2 feet up off of the batter or floor. In that config the robot -- were it standing on a flat floor -- the bumpers would not be in the bumper zone. Would a design like this violate R2 or R22 as the bumpers would not be in the BUMPER ZONE or perhaps it could be construed as the bumper being attached to an articulated part of the robot (that moves up and down)?
Thoughts?
Unread 11-01-2016, 12:24
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Scaling via jack up legs instead of "hanging"?
Really a Q&A question, but my thought is you would meet the definition of SCALED and red carded for violation of the robot rules regarding the bumper zone assuming you passed inspection in the first place. Otherwise interesting idea.
Unread 11-01-2016, 12:52
bEdhEd's Avatar
bEdhEd bEdhEd is offline
Design and Drive Team Mentor
AKA: Frank E.G. Shiner
FRC #0701 (The RoboVikes)
bEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond reputebEdhEd has a reputation beyond repute
Yes I think the problem one would run onto is that the jacks are still part of the robot, so if the bumper moves up two feet and the robot is still in contact with the batter, then the bumpers have exceeded the range at which they are allowed to be in relation to the bottom of the robot, which in the case of the jack, is at the contact point between jack and batter.
Unread 11-01-2016, 13:01
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
The bumper rule R22 is not defined wrt the bottom of the robot, but wrt the "ground when the robot is standing normally on the floor". It comes down to what "normally" means in this context.
Unread 11-01-2016, 13:58
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Interesting, but I still think "normally" perhaps is more vital to - (the configuration in which you were inspected), so if you weren't inspected while standing on jacks, then standing on jacks wouldn't be "standing normally on the floor." If you would normally "stand" on wheels, and your wheels no longer have contact with the floor, are you still "standing normally on the floor?"
I agree though. Something to be taken to Q and A for sure. Definitely needs some clarification.
Unread 11-01-2016, 14:07
Andrew Merwin Andrew Merwin is offline
FRC #5464 (Blue Jacket Robotics)
Andrew Merwin is an unknown quantity at this point
it does say that the root must be full supported by the tower. You still have to hang from it without touching the ground.
Are the jack up legs still going to touch the ground at the end of the match?
If so then you wouldn't be fully supported by the tower and not get the climbing points.
Unread 11-01-2016, 14:12
tStano tStano is offline
AKA: Sparks
Team Role: Electrical
tStano will become famous soon enough
The base (BATTER) of the tower is considered part of the TOWER.
Unread 11-01-2016, 14:15
Paul Richardson Paul Richardson is offline
Strategy/Mechanical/Drive Coach
no team (1477/3320)
Paul Richardson has a spectacular aura aboutPaul Richardson has a spectacular aura about
Check the definition of TOWER.
the part of the CASTLE constructed between PLAYER STATIONS two (2) and three (3)
with three (3) faces, three (3) RUNGS, five (5) GOALS, a BATTER, and a CORRAL
The BATTER is part of the TOWER, so just sitting on the BATTER you are fully supported by the TOWER.
Unread 11-01-2016, 14:20
bEdhEd's Avatar
Perhaps I should have been more precise. "Bottom" of the robot to me means where the robot stands on the floor normally. Do some people see the "bottom" of the robot as the lowest point of their chassis frame?
Unread 11-01-2016, 14:38
Engineering Mentor
Discussion echoing my thoughts around what does "standing normally" mean. My guess is Q&A will clarify that this will NOT be allowed.
To push the envelope a bit more -- what if I don't actually use legs but what if instead my basic drive train stays on the ground -- but my "perimeter frame" and the attached bumpers is the only part that rises up? How much of the robot is "enough" to raise and not cause issues with an R22 violation?
The liberal definition of "normally standing" would open up all sorts of very grey to egregious interpretations that would potentially allow me to play most of the match with no bumpers in a place where they are useful. For example, could I use my lifting jacks not on the batter to complete a SCALE but instead during a match to lift my robot and allow a ball acquisition mechanism to suck in a ball UNDER my bumpers?
Unread 11-01-2016, 15:23
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
Don't over think "normal". You take your robot in whatever operating configurations it might have and set it on level ground. If your bumpers are not in the bumper zone, your robot is not legal. So anything extending to the ground raising the bumpers out of the zone would be illegal. It is up to the team to show all operating configurations to the inspector.
While not specific to this question, if you have an illegal configuration during a match, and it is noticed by the referee, the best result you can hope for is being told to fix it and have your robot reinspected.
Unread 11-01-2016, 20:53
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
I don't think this is an "illegal configuration" though—the bumper rules only talk about the "normal" configuration. For a concrete example, in 2013 some teams had a jack that tilted them up 6 or so inches so they could start climbing the tower. Would you say they were violating the bumper rules as well? The theory is the same.
Anyway, I don't believe this is violating the spirit of the bumper rules either. Bumpers are designed to protect the robot from any rough collisions during the game, but during the last 20 seconds there are already heavy penalties again being contacted in any way by an opposing robot while attempting to scale.
Proud alum of CORE 2062.
www.core2062.com
Unread 12-01-2016, 08:52
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
I would have to go back and review the 2013 rules to have an opinion. But this isn't 2013 so that really doesn't matter. The 2016 rules do not reference an "normal configuration". R22 refers to the robot standing normally on a flat floor with configuration unspecified. As opposed to standing on a batten or other obstacle.
Unread 12-01-2016, 09:04
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
*sigh*
Some things don't change
http://www.angelbotics.com
Remember why you're doing this.
Unread 12-01-2016, 13:46
m1tche11d m1tche11d is offline
m1tche11d
FRC #1997
m1tche11d is an unknown quantity at this point
Do you know the team numbers of any of these teams, so I can find the archived match videos?
Thanks
