Go to Post I think overcoming obstacles together builds a stronger team. - MissInformation [more]
Unread 12-01-2016, 09:18
Masterchi45 Masterchi45 is offline
AKA: Chirayu Shah
FRC #5438 (Technological Terrors)
Rookie Year: 2015
Masterchi45 is an unknown quantity at this point
Send a message via Yahoo to Masterchi45
Defense or Offense?
What's happening! My team is almost done designing, but I had one question. Are you guys trying to approach the Defensive or Offensive Strategy? Are you aiming to put the ball in the tower? Just crossing the barrier and defending your "tower"? Or both? I just wanted to see what everyone is planning to do. Thanks!
Unread 12-01-2016, 09:25
Aaron (Awe-Sum)'s Avatar
Aaron (Awe-Sum) Aaron (Awe-Sum) is offline
4961 Strategy/Scouting Mentor
AKA: A-A-Ron
FRC #4961 (Shock and Awe-Sum)
Aaron (Awe-Sum) is an unknown quantity at this point
Re: Defense or Offense?
Our team is planning to bel be capable of breaching every defense, with the ability to score high or low goals as well.
2014: Howell Highest Rookie Seed
2014: Howell Rookie All-Star
2015: Centerline Quality Award
Unread 12-01-2016, 12:08
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Same here, as well as scaling. We've prioritized, so that we can decide which to pull from the design if (when) we realize that everything won't fit or something is just not working right. The pull items (Drawbridge and Sally Door) are ranked lowest, but we're working on designs for them nearly as intensely as the ball pickup and launch.
Unread 12-01-2016, 12:11
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
It's probably worth prioritizing whether it's better/faster/easier to design a mechanism to pull open a door or to design a small fast robot that could, for example, pop under the low bar, zip around and push open the door for an alliance partner.
