Go to Post Team newb: To expect any average group of high schoolers to build and develop a robot in less than six weeks is...madness! Me: Madness? THIS IS FIRST! - MishraArtificer [more]
View Poll Results: Most unused defenses?
Portcullis 34 17.53%
Cheval de Frise 32 16.49%
Moat 44 22.68%
Ramparts 17 8.76%
Drawbridge 22 11.34%
Sally Port 29 14.95%
Rock Wall 18 9.28%
Rough Terrain 33 17.01%
None 7 3.61%
Multiple Choice Poll. Voters: 194. You may not vote on this poll
Unread 09-01-2016, 17:29
howdosheeplamp's Avatar
howdosheeplamp howdosheeplamp is offline
I am the one who janks
AKA: Bijan Varjavand
FRC #2528
howdosheeplamp is just really nicehowdosheeplamp is just really nicehowdosheeplamp is just really nicehowdosheeplamp is just really nice
Question Most unused defense of 2016?
Since your alliance is forced to choose only 1 defense from each category, and your defenses should be as hard to breach as possible, it's seems clear that teams will pick the toughest defenses to cross. Some defenses seem harder to cross than the other in their category, and will probably be picked much more often than their counterpart.
What do you think will be the most unused defense of 2016? Personally, I think it'll be the rough terrain as it doesn't look like it'll slow down the enemy robots as much as the rock wall.
These are just guesses though, I have no idea what method of transportation teams are going to end up deciding on.
Unread 09-01-2016, 18:14
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Re: Most unused defense of 2016?
Category A: Portcullis v. Cheval de Frise
The Portcullis allows for has one part to move, and can be contacted in on place, but it must be lifted over the height of the robot passing through. A short robot could possibly have a passive mechanism that allows them to drive under the Portcullis.
The Cheval de Frise could be contacted in one place if the robot was shorter than the width of three of the tilting platforms, but would require some finer alignment. CoG of the robot will need to have attention paid to it.
There is opportunity for one mechanism to be capable of handling both these DEFENSES.
Category B: Moat v. Ramparts
The Moat and Ramparts are two parts of the same issue, a robot's CoG and potential high-centering. Given a low enough CoG and proper clearance, a robot should be able to just as easily pass over either of these.
Category C: Drawbridge v. Sally Port
The Drawbridge and Sally Port are both interesting DEFENSES. They will be easily opened from the courtyard side, needing nothing more than robots capable of traversing the field. Trying to tackle these two DEFENSES from the front will prove to be time consuming.
These DEFENSES can be tackled relatively quickly with the ALLIANCE working together by having one robot open the DEFENSE and the other two robots come through.
Both of these DEFENSES will be time consuming for those that do not plan before the match. They will pose no issue for prepared ALLIANCES.
Category D: Rock Wall v. Rough Terrain
Remember how intimidating the Barrier from Rebound Rumble appeared? The Rock Wall is only a half inch taller. Teams that design for it will have no issue crossing this DEFENSE. Also, any robot capable of traversing the Rock Wall should have no issue with the DEFENSES from Category B.
The Rough Terrain would prove quite a bit more difficult. due to the varying heights and one and a half inch gaps between the tubing pieces, there are plenty of opportunities for robots to get wheels stuck or high center.
Low Bar
The Low Bar is straight forward in its method. If you are too tall, you have to pass by one of the other DEFENSES.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 09-01-2016, 18:23
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
FIRST can be pretty intentional with the details of their designs. That extra half inch on the rock wall might be more problematic than it would appear. The Barrier from RR was indeed crash-over-able but only just for most conventional / kit frames.
Jim Browne, EIT
Team 1058 - PVC Pirates
Unread 12-01-2016, 08:07
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Having spent two evenings looking for a drive configuration that can cross all of the "drive over" class B and D defenses (while also fitting under the low bar), I think there will be teams that have trouble with each of them. I expect the same of the moving class A and C defenses. I doubt that there's any one that will be so generally easier than its counterpart that any of the obstacles will be "unused".
Edit: especially not the moat, which is currently in the lead. That was the hardest one not to have some failure mode, whether high centered over one edge, nose-in, or high-supported by both ends.
Edit2: I managed (in drawings) to get a robot with 5" of ground clearance stuck in the moat, or at least prevented from continuing to move forward. That spacing between two tall thin walls stymies many of the patterns I tried that could traverse the other non-articulated defenses. Most of the designs that had no trouble with the moat got caught on at least one of the rock wall or ramparts or rough terrain.
Unread 12-01-2016, 08:19
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
James Juncker will become famous soon enough
If I could point out what I had said before in a different thread, http://www.chiefdelphi.com/forums/sh...hreadid=141458
People need to stop thinking that they need to select the most difficult defenses(at least for Qualification rounds). similarly the defenses will change drastically based on the robots that you are facing, as each team will have designed their robot for their specific defenses.
The longest traverse time from my estimates of any obstacle would be the Portcullis at about 5-15 seconds depending on lift speed as well as robot height. after this the next longest would be Sally Port / Drawbridge from the outside without inside assistance. these would take about 5-10 seconds. Low bar is about 2 seconds if you can do it and the terrain defenses vary from 3-7 seconds.
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
Unread 12-01-2016, 08:26
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Clever teams will be able to handle the defenses quickly and effectively. The biggest obstacle I see with the defenses is their physical size as visibility blockers.
I believe at early stages of the event, many teams will ignore the tallest elements (Drawbridge, Portcullis) to aid visibility. As strategies get more refined, alliances will then artfully place the Drawbridge and Portcullis in the line-of-sight from their own tower to the opposing alliance's perceived most powerful member's driver station.
Hi!
Unread 12-01-2016, 09:42
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
I'm surprised by the number of people who think the moat will be underutilized. Basically any team with less than 2.5" ground clearance is likely to struggle with it. I'm a little confused by the term "unused," does this mean the defense to be the least frequently placed or least frequently crossed?
Personally, I think the defense that will be the least frequently crossed is the Cheval. It's probably the most sensitive of any of the defenses, and requires an amount of precision far greater than most of the others. A short robot, as Ri3D Redacted is trying to prove, should be able to get through the portcullis passively, so it could end up being a relatively easy defense for some robots. However, the portcullis also offers some awesome utility as a vision block, which may make it a great pick into an alliance that focuses on capture points.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 12-01-2016, 09:58
vhcook's Avatar
vhcook vhcook is offline
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I'm thinking the drawbridge will get the least use, as it's a visibility blocker, easily opened from inside, and from outside requires a simpler motion to open than the sally port.
The portcullis is at least slightly transparent and is a harder obstacle to resolve, so I think it will get used more in spite of its height. The cheval de frise requires some specific design to deal with as well, so I expect the overall usage to be fairly even (and aligned with strategic knowledge of the opponents).
The category B and D defenses really depend a lot on the opposing drivetrain, so I think they'll level out.
Unread 12-01-2016, 10:01
Hgree56's Avatar
Hgree56 Hgree56 is offline
AKA: Hunter Greene
FRC #4272 (Maverick Boiler Robotics)
Hgree56 will become famous soon enough
After watching Ri3D videos multiple times, I feel like the moat will be the least used. With a 6WD that is powered in the center, you can climb over both bars easily.
2016 Indiana Tipp. District Industrial Safety Award winner
2016 Indiana Perry M. District QF w/ (3487 & 4580)
2015 Indiana Purdue District Chairman's Award winner
2015 Indiana Indianapolis District QF w/ (5403 & 4008) and Industrial Safety award winner
2015 Indiana Indianapolis, Purdue, and State Champs Industrial Safety Award Winner
2014 Crossroad GP Award Winner
2014 Boilermaker SF w/ (337 & 4213)
Unread 12-01-2016, 10:06
c.shu's Avatar
c.shu c.shu is offline
Alumni/Mechanical/CAD
AKA: Cole Shumaker
c.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to beholdc.shu is a splendid one to behold
So far our Ri3D group has had the most trouble with the Rough Terrain obstacle. Most of the others are fairly easy to tackle with a good design, where with the Rough Terrain the different levels of blocks combined with the somewhat random placement of them can find you bottomed out a lot faster than you would expect.
