Go to Post The great thing about posting questions here is everybody can see the answers. - Kevin Thorp [more]
Unread 12-01-2016, 09:47
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Tank tread bumpers?
your bumpers must be place on a rigid surface at least on the first 8" of each corner... i guess your frame would have to go around those threads
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-01-2016, 14:43
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Not necessarily, you're mixing two rules together.. As long as you have a rigid surface in the same plane as the treads, and your bumpers covered at least 8 inches of each corner, you'd be in compliance. An example would be if the bumper was fastened to 2 L brackets attached to some 80-20.
R19 ROBOTS are required to use BUMPERS to protect all outside corners of the FRAME PERIMETER. For adequate protection, at least 8 in. of BUMPER must be placed on each side of each outside corner...
and
R21 section G. must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame
Unread 12-01-2016, 17:34
Drive Coach
AKA: Antoine L.
and
that's right but your drawings above put the bumpers over the threads. The plywood backing have to start beyond the threads
Unread 12-01-2016, 19:00
I specifically said "Not drawn to scale or anything."
Unread 12-01-2016, 22:24
DonRotolo's Avatar
Back to humble
FRC #0832
Treads, not threads
Unread 12-01-2016, 22:26
Drive Coach
AKA: Antoine L.
Originally Posted by DonRotolo View Post
Treads, not threads
happens when english is not your native language
