Go to Post By far, the worst thing about it was the severe lack of cowbell. There was no cowbell what so ever. Had there been cowbell that would have completely changed everything for me. - Wildcat [more]
Unread 11-01-2016, 20:24
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
8" Non-Pneumatic Wheels
Rookie team 6054 here, we have the KOP drivetrain (Square Orientation), and we would like to go to 8" wheels. The conversion to the pneumatics upgrade is beyond our financial means, but we are considering switching out our wheels with these (http://files.andymark.com/x2010-8-FIRSTwheel.pdf). We will have to relocate a couple churros to make it works.
Anyone knows how these will work on the different playing surfaces? Any Obvious problems were overlooking?
Unread 11-01-2016, 20:37
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
Re: 8" Non-Pneumatic Wheels
I couldn't see the file but Im guessing you are talking about the plaction or rubber treaded wheels (white/ blue ones). I think that there is a small possibility of them getting stuck in the rough terrain, but I think you are on the right track with 8 inch wheels for this year. Best of luck!!
Unread 11-01-2016, 20:40
FRC #6054 (Dukes)
The ones we were looking at were from the 2010 kit and are plastic with gray rubber on the outside.
Unread 11-01-2016, 20:47
jmar896 jmar896 is offline
FRC #0157
jmar896 is an unknown quantity at this point
I think you are talking about this type of wheel, right?
http://www.andymark.com/product-p/am-0420.htm
Unread 11-01-2016, 20:55
messer5740's Avatar
Team Role: Driver
Rookie Year: 2015
Yeah I would avoid the rough terrain because the blocks are spaced out a larger width than the wheels- but hey you most likely will be allied with a team that CAN pass rough terrain and again its only one defense.
Unread 11-01-2016, 21:12
Doug Frisk's Avatar
Doug Frisk Doug Frisk is online now
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
Given this is likely to be a game with vigorous robot to robot contact how would those hold up to being T-Boned?
Unread 11-01-2016, 23:02
FRC #6054 (Dukes)
Yes, That's the one.
Unread 11-01-2016, 23:16
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Have you checked whether the larger 8" wheels will collide with the front and back "C" frames ? If so, is it possible to notch the frame to accommodate the extra 1" wheel radius ? Else you have to move the axles and then the belts don't fit.... Or extend the frame
Also keep in mind when going from 6 to 8 inch and not changing any gear or belt pulley ratios, the robot will go slightly less than 8/6 times faster. Though your driver does has a "throttle", it might be somewhat harder to control the robot in close in maneuvering. And the robot will have 8/6 less torque (in a pushing match).
Unread 11-01-2016, 23:35
FRC #6054 (Dukes)
We are going to change our gearing to regain some torque, and it's very close on the notching, so I think we will see how it fits together to se if we need to notch
Unread 11-01-2016, 23:38
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Agreed!
http://www.robotmarketplace.com/products/BPDWC22.html
Would be my choice. Pneumatic will likely be better, but in a pinch, I'd go with Colsons.
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
Unread 12-01-2016, 00:31
snoman's Avatar
snoman snoman is offline
FRC #3275 (Accelerators 3134 & Regulators 3275)
snoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to beholdsnoman is a splendid one to behold
We tested today 8in 4wd gray wheels didn't make it over the mote . We are testing with 20in AM nano tube s going to try 6wd tomorrow.. that should work?? Maybe
Coach of the Cass Lake Bena Regulators 3275 (Boys)and mentor Accelerators 3134(Girls)
https://www.facebook.com/accerleratorsandregulators/
https://www.youtube.com/channel/UCQU...Cr8I4wezAbMefA
Unread 12-01-2016, 00:48
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Originally Posted by EricDrost View Post
Agreed!
These look really nice, is there anyone who has used these before to comment on their "compression"? The pneumatic wheels are a tad too pricey for us to prototype with and we've never used colsons before.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 12-01-2016, 01:07
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Not much at all. They grip decently but are by no means "squishy"
Unread 12-01-2016, 12:20
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Agreed!
Would you elaborate on the betterness of pneumatic? In 2012, I saw some teams really struggle with 8" pneumatic (esp with 4 wheel skid steer).
I am trying to campaign for traction wheels of some sort. Really like your colson suggestion. Even with the vex hub added they seem to be $14 cheaper per wheel than the AM 8". Plus they are a true 8" rather than 7.65".
If there are things that I am not taking into account I would be very glad to learn.
Alan Gilgenbach
C.O.R.E 2062
Unread 12-01-2016, 12:26
george.tan's Avatar
george.tan george.tan is offline
Raider Power!
AKA: George
FRC #3005 (RoboChargers)
george.tan is on a distinguished road
I don't think they're as grip as well as the newer wheels. Also I'm pretty sure we broke 1 or 2 of them while conducting some extreme testing. They never made it on our robot for 2010. We used traction wheels instead.
