Go to Post Just remember that you can get just as much inspiration from making a simple system's details work really well as you can from just making a complex system work... - Rob [more]
Unread 12-01-2016, 12:40
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Re: 8" Non-Pneumatic Wheels
Originally Posted by EricDrost View Post
Agreed!
http://www.robotmarketplace.com/products/BPDWC22.html
Would be my choice. Pneumatic will likely be better, but in a pinch, I'd go with Colsons.
Any suggestions on how we could go about mounting the pulleys onto those wheels?
Unread 12-01-2016, 12:50
Knufire Knufire is offline
Dead axle hub: http://www.vexrobotics.com/colsonhubs-g.html
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 12-01-2016, 12:57
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
Originally Posted by Knufire View Post
Yeah, you get this hub, and press it into the Colson with an arbor press. They work great. We are not using Colsons this year, but they are a much better option over the kit wheels you have linked, they are pretty much indestructible, but they are heavy.
Good luck!
Unread 12-01-2016, 15:37
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by de_ View Post
Have you checked whether the larger 8" wheels will collide with the front and back "C" frames ? If so, is it possible to notch the frame to accommodate the extra 1" wheel radius ? Else you have to move the axles and then the belts don't fit.... Or extend the frame
Also keep in mind when going from 6 to 8 inch and not changing any gear or belt pulley ratios, the robot will go slightly less than 8/6 times faster. Though your driver does has a "throttle", it might be somewhat harder to control the robot in close in maneuvering. And the robot will have 8/6 less torque (in a pushing match).
There is a separate pair of axle holes for 8" wheels already in the inner and outer plates. You will need to get shorter belts, as specified in the KoP documentation.
