Go to Post We always have a party on Friday. It's called scouting. - Meredith Novak [more]
Unread 12-01-2016, 11:11
AKSoapy29's Avatar
AKSoapy29 AKSoapy29 is offline
Driver, Prog, Elec, Pneu, Etc.
AKA: Andrew K.
FRC #2169 (KING TeC)
AKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura aboutAKSoapy29 has a spectacular aura about
Question Team Flags
Hi. Does anyone know when or if the official Q&A is active, and where it is? I'm wondering if it is legal for teams to use retro reflective tape in their flags. I'm worried that this could screw up teams vision tracking abilities.
Thanks,
Andrew K.
Andrew K.
KING TeC 2169
League of Veterans - FTC3385
Head of Web, Primary Driver, Programming, Electrical, Pneumatic
Unread 12-01-2016, 11:17
jgerstein jgerstein is offline
FRC #1257 (Parallel Universe)
jgerstein has much to be proud ofjgerstein has much to be proud ofjgerstein has much to be proud ofjgerstein has much to be proud ofjgerstein has much to be proud ofjgerstein has much to be proud ofjgerstein has much to be proud ofjgerstein has much to be proud of
Re: Team Flags
The official Q&A will be opened tomorrow, according to TIMS.
There should be a link here when it opens. In order to submit a question, a mentor on your team will have to get the login info from TIMS, as accounts for the Q&A exist per team, not for individuals.
Unread 12-01-2016, 11:19
EDesbiens's Avatar
EDesbiens EDesbiens is offline
Passionate crackpot
AKA: Étienne Desbiens
FRC #5859 (i)
EDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of lightEDesbiens is a glorious beacon of light
Re: Team Flags
Standards should reflect your team’s identity and must be decorated in the spirit of FIRST and Gracious Professionalism. They
may not include retroreflective tape
or elements that mimic History Patches, or Achievement Streamers (those are reserved
for teams earning them). Standards may not be designed such that they blind or distract field crew, opponent drivers, or
audience members. During a match, the Standard must be fixed, physically and visually (i.e. no strobing, flashing, changing
color, etc.).
Here, from the standard specs : http://www.firstinspires.org/sites/d...ifications.pdf
Lisa: Players play and managers manage.
Ralph: Do alligators alligate?
Unread 12-01-2016, 14:02
AKSoapy29's Avatar
AKA: Andrew K.
Re: Team Flags
Thank goodness that is the case. I'm sure some team out there would have done it. It could have been used to cheat on a bot that uses it.
Thank you for linking us to that!
Andrew K.
KING TeC 2169
Unread 12-01-2016, 14:16
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
Re: Team Flags
I wonder if you could put a camera on the Standard, it would give you a huge advantage as far as visibility over the outer works goes.
Unread 12-01-2016, 14:58
EDesbiens's Avatar
Passionate crackpot
FRC #5859 (i)
Re: Team Flags
You can't...
Originally Posted by Team Standard Specifications
Altogether, elements of the Standard (does not include support pieces) may not
exceed a volume that’s 12” wide x 24” tall x 3” deep (305mm x 610mm x 76mm). The
Standard may be any shape.
Wires can't get out of that box...
Originally Posted by R95
Other than the system provided by the ARENA, no other form of wireless communications shall be used to communicate to, from, or within the OPERATOR CONSOLE.
And you can't have a wireless camera.
