Go to Post Boy was that a sleepless night! - Suneet [more]
Unread 11-01-2016, 17:26
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
gbear605 is an unknown quantity at this point
No Robot Code on the RoboRIO
We are still using the 2015 Control System and all the code from last year. We haven't updated WPILib. When I load the code to the robot, this is the log:
Trying to override old definition of task classloader
clean:
   [delete] Deleting directory /Users/Nashoba/Programming/2016-Pre-Season-Drivetrain/build
   [delete] Deleting directory /Users/Nashoba/Programming/2016-Pre-Season-Drivetrain/dist
compile:
    [mkdir] Created dir: /Users/Nashoba/Programming/2016-Pre-Season-Drivetrain/build
     [echo] [athena-compile] Compiling src with classpath=/Users/Nashoba/wpilib/java/current/lib/WPILib.jar:/Users/Nashoba/wpilib/java/current/lib/NetworkTables.jar to build
    [javac] Compiling 22 source files to /Users/Nashoba/Programming/2016-Pre-Season-Drivetrain/build
jar:
     [echo] [athena-jar] Making jar dist/FRCUserProgram.jar.
    [mkdir] Created dir: /Users/Nashoba/Programming/2016-Pre-Season-Drivetrain/dist
    [mkdir] Created dir: /Users/Nashoba/Programming/2016-Pre-Season-Drivetrain/build/jars
     [echo] [athena-jar] Copying jars from /Users/Nashoba/wpilib/java/current/lib/WPILib.jar:/Users/Nashoba/wpilib/java/current/lib/NetworkTables.jar to build/jars.
     [copy] Copying 2 files to /Users/Nashoba/Programming/2016-Pre-Season-Drivetrain/build/jars
      [jar] Building jar: /Users/Nashob/Programming/2016-Pre-Season-Drivetrain/dist/FRCUserProgram.jar
get-target-ip:
     [echo] Trying Target: roboRIO-1768.local
     [echo] roboRIO found via mDNS
dependencies:
     [echo] roboRIO image version validated
     [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s/4485/m/13503/l/288822-installing-java-8-on-the-roborio-using-the-frc-roborio-java-installer-java-only
  [sshexec] Connecting to roboRIO-1768.local:22
  [sshexec] cmd : test -d /usr/local/frc/JRE
deploy:
     [echo] [athena-deploy] Copying code over.
      [scp] Connecting to roboRIO-1768.local:22
      [scp] done.
  [sshexec] cmd : killall netconsole-host
      [scp] done.
      [scp] done.
     [echo] [athena-deploy] Starting program.
  [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r;
  [sshexec] start-stop-daemon: warning: killing process 1761: No such process
BUILD SUCCESSFUL
Total time: 11 seconds
However, the Comm light on the RoboRIO is red (indicating no code) and the Driver Station says there is no code on the robot.
Unread 12-01-2016, 10:09
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: No Robot Code on the RoboRIO
Looks like your code is erroring out. Can you post a riolog dump as well? and the driver station error log if there is any content there.
Unread 12-01-2016, 10:39
gbear605's Avatar
Scarebear
There is no driver station error log. How do I find the roborio log?
Unread 12-01-2016, 10:45
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Instructions for opening Riolog are available on ScreenSteps here: http://wpilib.screenstepslive.com/s/...console-output. Instructions are about halfway down the page.
Unread 12-01-2016, 14:30
gbear605's Avatar
Scarebear
The only thing that the Riolog says is
➔ Launching «'/usr/local/frc/JRE/bin/java' '-jar' '/home/lvuser/FRCUserProgram.jar'»
Unread 12-01-2016, 19:14
gbear605's Avatar
Scarebear
Okay, by commenting out code, I've narrowed it down to
for(; i*maxAcc < maxSpeed; i += 0.01) {}
being the issue.
This happens because maxAcc = 0, since I hadn't found the value yet... Oops.
Thanks for the help at narrowing it down to being a code issue.
