Go to Post "Its not a glitch its a new feature, we just dont know how to use it yet" - Cuog [more]
Unread 11-01-2016, 21:12
Iron Giant Iron Giant is offline
FRC #4956
Iron Giant is an unknown quantity at this point
Sally Door
What material is the Sally Door made of. I see the Drawbridge is made of Polycarbonate but I don't see the material for the Sally Door.
Unread 12-01-2016, 13:51
autobot's Avatar
autobot autobot is offline
FRC #0836
autobot will become famous soon enough
Talking Re: Sally Door
I believe the sally door is made of the same material.
Hope this helps
Unread 12-01-2016, 14:02
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Re: Sally Door
NOTE:
Material: clear polycarbonate, .125"Thick
Scale: 1:8
QTY: 1
Print to look like wood
Per dwg GE-16044 pg 90/290 of 2016 Field Component. Wow those drawings are a pain to read!
Alan Gilgenbach
C.O.R.E 2062
Unread 12-01-2016, 14:27
GreyingJay GreyingJay is offline
Robonut
AKA: Mr. Lam
FRC #2706 (Merge Robotics)
Rookie Year: 2015
GreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond reputeGreyingJay has a reputation beyond repute
Re: Sally Door
That seems really thin.
Unread 12-01-2016, 14:29
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Re: Sally Door
Originally Posted by Iron Giant View Post
Sally Door
Yes, Sally Door.
Unread 12-01-2016, 14:37
MisterG's Avatar
Re: Sally Door
Your response got me to dig a bit deeper. From page 82.
NOTE: Place two GE-16044 parts front
to back, so that the printing is
sandwiched between the clear portions
of the polycarbonate, also making
sure that the holes line up properly.
Secure those parts to the Door Frame
with 1/4"-20 hardware called out in
BOM.
Have I said that I have never been a fan of the field drawings?
Alan Gilgenbach
C.O.R.E 2062
Unread 12-01-2016, 14:39
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
Re: Sally Door
While we're on the question of the sally door (and by extension the drawbridge) . Since they both extend out into the neutral zone when opened all the way, does anyone know if it is a viable strategy (counting as crossing a defense) to -
  • open them from the courtyard (easy) side
  • get the robot and bumpers completely in the neutral zone while still holding them open
  • bounce the door so you're not touching it for a moment (so you are for that moment completely in the neutral zone and not touching a defense)
  • still propping the door open after the bounce then
  • proceed through the defense completely into the opponent's courtyard
I thought it would be but might be tricky to get the ref to see it that way.
Unread 12-01-2016, 19:53
Re: Sally Door
If the ref (or scorekeeper) doesn't see it, it didn't happen. And trust me, they're going to be busy looking all over the place.
Is it a valid crossing? Yep. Will it get scored as one? I'd go 50-50 on that, or worse.
Unread 12-01-2016, 19:54
Michael Hill's Avatar
Re: Sally Door
yes, Sally Door.
Unread 12-01-2016, 20:27
cj3958's Avatar
cj3958 cj3958 is offline
FRC #5234 (Marauderbots)
cj3958 will become famous soon enough
Re: Sally Door
Yes. The doors are extremely thin. I was at the full field in Manchester, and yes, they are incredibly thin and incredibly bendy. The sally door is a little bit less flexible because it has a triangle brace thing so it is only floppy like polycarb the upper half of it.
The draw bridge on the other hand is ridiculously floppy. Not only will it be hard to just get to the ground, but when its on the ground if you hold it there from the edge of the door, the polycarb bows up quite a bit from the springs that pull it back up when you let go*. It will be extremely difficult for any team to open it without just going through the courtyard and holding the door open for your partners.
As far as the punching idea goes, that ones a toss up as to whether or not its legal. I think it most likely will be illegal because its too much work to ask the refs to keep track of that and I believe that they said somewhere the robot has to be free and clear of the defense in the neutral zone for it to count as a breach(I forget the exact wording), and even though you may not be touching the defense, I personally would not call you free and clear of it. But that is just my 2 cents.
* As a sidenote... The plywood door Ri3D 1.0 used is not at all acurate and there is no way that robot will be able to lower the door on its own. Make sure you plan on this when you design your mechanisms. I know soooooooo many teams will think that their robot will be able to do the door and show up at the event only to find that the door is not even close to the door they had at home.
Current Lead Mechanical Mentor for 5234 the marauder-bots http://www.marauderbots.com/
Previously a student for one year on team 246 - Overclocked and 3 years on 3958 - Schodinger's Cat
Unread 14-01-2016, 15:31
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Re: Sally Door
Yes - I also noticed how flexible the Drawbridge was in Manchester. Plan on it curving forward about 30 degrees if you're pulling it down from the top.
I assume the wooden Drawbridges we build will be stiffer. Keep that in mind when you're designing your solution.
Mentor, Team 3489, "Category 5"
Ashley Ridge H.S. & Summerville H.S.
Summerville, SC USA
