Go to Post There's so much to say about a sponsor who gets involved and cares about your team over one who just signs a check. - galewind [more]
Unread 09-01-2016, 21:23
tig567899's Avatar
tig567899 tig567899 is offline
Team 6070 Programming Captain
AKA: Tiger Kong
FRC #6070 (Gryphon Machine)
Rookie Year: 2016
tig567899 is an unknown quantity at this point
C++ Code Not working
I started a new code using c++, and I keep getting the error 'Invalid arguments' on the line:
START_ROBOT_CLASS(Robot);
Has someone experienced the same problem? Thanks.
Unread 09-01-2016, 22:13
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
Re: C++ Code Not working
Is that error being shown by the Eclipse indexer, the build console, or both? Did you start from an example project, and if so, which was it?
Unread 10-01-2016, 00:24
Did you do the step "Rebuilding the index"?
http://wpilib.screenstepslive.com/s/...p-test-program
Unread 10-01-2016, 14:51
ETGH ETGH is offline
FRC #3045
ETGH is an unknown quantity at this point
We are having the same problem - and rebuilding the index doesn't fix it. Any other suggestions?
Unread 10-01-2016, 15:06
calcmogul's Avatar
WPILib Developer
AKA: Tyler Veness
I've found the indexer to not be the ultimate authority on whether one's C++ code compiles. Try building the project and seeing if that error prints in the build console as well. If it doesn't and the build succeeded, you can ignore the indexer.
Unread 12-01-2016, 11:40
tig567899's Avatar
AKA: Tiger Kong
Rookie Year: 2016
The error is in the "Problems tab" on eclipse, and prevents the thing from building. I've tried rebuilding, and the problem occurs on every type of robot program (sample, iterative, example robot program).
Unread 12-01-2016, 14:50
DamenStar DamenStar is offline
FRC #1410
DamenStar is an unknown quantity at this point
Normally the START_ROBOT_CLASS(Robot) statement should sit outside the main class normally in Robot.cpp. It should be located outside of any defined method:
#include "WPILib.h"
#include "Robot.h"
OI * Robot::oi = NULL;
DriveBase * Robot::drivebase = NULL;
void Robot::RobotInit(){
	oi = new OI();
	drivebase = new DriveBase();
It would be great if you post your code that you are having a problem with.
See ya in the bitstream
Unread 14-01-2016, 09:38
tig567899's Avatar
AKA: Tiger Kong
Rookie Year: 2016
I have screenshotted the thing but this forum doesn't let me post the image.
The code is below:
#include "WPILib.h"
class Robot: public IterativeRobot
private:
	void RobotInit()
	void AutonomousInit()
	void AutonomousPeriodic()
	void TeleopInit()
	void TeleopPeriodic()
	void TestPeriodic()
The error is: Invalid arguments', line 38, which is the START_ROBOT_CLASS(Robot); line.
