Re: Fastest way to score the Most points
You can score 17 or 22 points if you do reach after you score the high goal and go back to the outerworks "REACH an act performed by a ROBOT, such that at the end of the AUTO period, any part of a ROBOT’S BUMPERS are within the opponent’s OUTER WORKS" |
Fastest way I can envision....
Three Scaling Bots 45 Three Auto max bots (Cross, HG) 60 <Fastest way less than 15 secs Then Best HG scorer stays in position in opponents courtyard Low Specialty/HG bot that somehow bridges the Secret passage to Courtyard expanse like a "REPEATER"..... Can intake HP bowled Boulders and somehow force them under Low goal engineered to get bowled boulders and expel under low goal to High Shooter. So so far Castle is weakened by 3 in auto so 5 more bowled boulders (HP- Specialty- HIGH Shooter) will weaken it In the Meantime the Tank Bot/HG specialist works on destroying defenses. After Castle is Weakened the Specialty bot destroys the low goal Getting Breach Points in combo with at least three from Tank Bot All Three then Scale. Achieving Max score +4RP per game I'm convinced some team will find that specialty bot to allow a repeated bowl to a High Point shooter (Most efficient reliable supply of boulders at least three from HP and any scored on you)---this years modular ramp bot Last edited by Boltman : 12-01-2016 at 16:44. |
All-in-all, the fastest way to score the most points, is to have all robots score 20 points, breach the defenses, score an unbelievable amount of High Goals, and have all robots scale the tower. If all 3 robots can score like our robot (1073) is predicted to, the alliance will score 25-30 High Goals on a good day.
Easy. Follow the points.
Let's clarify that you do not have to bring a boulder through a defense to weaken it.
#7
True, but while you're on that side you may as well drop a present into the tower--that's -1 strength to the tower, and +2 or +5 points to you.
