Go to Post I'm here to unintentionally offer insightful quotes. - Jeff Waegelin [more]
Unread 09-01-2016, 22:36
Hasan333's Avatar
Hasan333 Hasan333 is offline
69
AKA: Hasan
FRC #0333 (The megalodons)
Hasan333 is an unknown quantity at this point
Fastest way to score the Most points
Any ideas on what's the fastest way to score, some of my ideas are to get the 15 or 20 points in auto then avoid the defenses and go through the low bar score the boulder into the high goal and go get another boulder and repeat, same scenario but instead of high goal score into the low goal to save time? end game scale for 15 points.
Unread 09-01-2016, 22:43
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is offline
FRC #4536 (MinuteBots)
Re: Fastest way to score the Most points
Originally Posted by Hasan333 View Post
Any ideas on what's the fastest way to score, some of my ideas are to get the 17 or 22 points in auto then avoid the defenses and go through the low bar score the boulder into the high goal and go get another boulder and repeat, same scenario but instead of high goal score into the low goal to save time? end game scale for 15 points.
I'm curious to know how you think you will be scoring 22 points in auto.
Unread 09-01-2016, 22:48
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
it would be 20 1 cross and 1 high goal auto points are tallied at the end of auto (this is how I remember it) so you can only score 1 cross and would not score the reach.
Unread 09-01-2016, 22:49
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Since the REACH points are assessed at the end of autonomous, and the robot cannot go back to get REACH points after receiving the CROSS points, the net points are 15 or 20 in your scenario.
(emphasis mine)
Originally Posted by Section 3.1.3
ROBOTS can also receive AUTO points for REACHING a DEFENSE. A DEFENSE is REACHED when, at the end of the AUTO period, any part of a ROBOT’s BUMPERS are within the opponent’s OUTER WORKS. Once a ROBOT CROSSES a DEFENSE in AUTO, any additional DEFENSES that ROBOT REACHES or CROSSES during the AUTO period will not decrease DEFENSE STRENGTH nor contribute points to the ALLIANCE.
I won't say much since for the first time in many years we aren't finished with all of the scoring scenarios and potential alliance makeups - but we have assessed that a scaling robot which goes under the low bar will make packaging everything very tight.
We've also assessed that "IT'S A TRAP" may gain renewed infamy this year amongst all of the star wars fans...
GitHub
Unread 09-01-2016, 22:58
Hasan333's Avatar
69
AKA: Hasan
Reaching a defense you get 2 points, 10 points for crossing, 5 points for low goal, =17, or if high goal 22 points, unless if reaching only gives you points for reaching and staying there, which is unlikely to me
Unread 09-01-2016, 23:18
Orthofort's Avatar
Orthofort Orthofort is offline
FRC #2832
Orthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to all
Section 3.1.3 outlines that once a robot has gained a crossing, no more points for crossing/reaching can be given in auto to that robot.
Unread 09-01-2016, 23:21
Hasan333's Avatar
69
AKA: Hasan
thanks for the clarity
Unread 12-01-2016, 15:49
Hasan333's Avatar
69
AKA: Hasan
You can score 17 or 22 points if you do reach after you score the high goal and go back to the outerworks "REACH an act performed by a ROBOT, such that at the end of the AUTO period, any part of a
ROBOT’S BUMPERS are within the opponent’s OUTER WORKS"
Unread 12-01-2016, 15:53
FRC #1360
Regardless of when you do your REACH, if you already CROSSED, you cannot earn more points unless its scoring a goal.
Unread 12-01-2016, 16:40
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Fastest way I can envision....
Three Scaling Bots 45
Three Auto max bots (Cross, HG) 60 <Fastest way less than 15 secs
Then Best HG scorer stays in position in opponents courtyard
Low Specialty/HG bot that somehow bridges the Secret passage to Courtyard expanse like a "REPEATER"..... Can intake HP bowled Boulders and somehow force them under Low goal engineered to get bowled boulders and expel under low goal to High Shooter.
So so far Castle is weakened by 3 in auto so 5 more bowled boulders (HP- Specialty- HIGH Shooter) will weaken it
In the Meantime the Tank Bot/HG specialist works on destroying defenses.
After Castle is Weakened the Specialty bot destroys the low goal
Getting Breach Points in combo with at least three from Tank Bot
All Three then Scale. Achieving Max score +4RP per game
I'm convinced some team will find that specialty bot to allow a repeated bowl to a High Point shooter (Most efficient reliable supply of boulders at least three from HP and any scored on you)---this years modular ramp bot
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 12-01-2016, 16:57
InspectorGadget1073's Avatar
InspectorGadget1073 InspectorGadget1073 is offline
Jedi Master
FRC #1073 (The Force Team)
InspectorGadget1073 is an unknown quantity at this point
All-in-all, the fastest way to score the most points, is to have all robots score 20 points, breach the defenses, score an unbelievable amount of High Goals, and have all robots scale the tower. If all 3 robots can score like our robot (1073) is predicted to, the alliance will score 25-30 High Goals on a good day.
"I'm a human entropy producer." ~Dean Kamen, Our Lord and Savior
Unread 12-01-2016, 17:15
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Easy. Follow the points.
  1. Nail autonomous. Put your robots through different defenses.
  2. Quickly carry boulders through a variety of defenses. Between auto and teleop, bring 2 balls through each of the five defenses and score them high.
  3. Continue scoring boulders quickly. Preferably through the high goal, probably through the low bar for minimum cycle time.
  4. Have all three robots at least challenge, and preferably scale the tower.
Unread 12-01-2016, 19:42
sonichammer7476's Avatar
sonichammer7476 sonichammer7476 is offline
FRC #3959 (Morgan County Mech Tech)
Team Role: Scout
sonichammer7476 has a spectacular aura aboutsonichammer7476 has a spectacular aura aboutsonichammer7476 has a spectacular aura about
Let's clarify that you do not have to bring a boulder through a defense to weaken it.
Unread 12-01-2016, 20:03
True, but while you're on that side you may as well drop a present into the tower--that's -1 strength to the tower, and +2 or +5 points to you.
