Go to Post Sleep? What this you talk about. I never can sleep the night before kick-off. - midway78224 [more]
Unread 12-01-2016, 15:52
crollison crollison is offline
AKA: Chris Rollison
FRC #4809 (Black Knight Robotics)
crollison is an unknown quantity at this point
Imported STL Files
(Edit STEP for STL) - too much 3d printing.
Trying to design in Inventor, creating own parts and working with them I can get by, but I'm stuck with imported files. We have opted to build our own drivetrain this year and I'm importing STEP files of 1X2 Stock. How do I import a part and edit it to the correct dimension? This should be simple, but I've battled it for a while and it's beating me. Thanks.
Unread 12-01-2016, 16:00
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Imported STL Files
For simple stock shapes, you're probably better off making a new part, sketching the profile, and extruding to length.
If you really need to cut an imported part, first you'll want to save a copy just in case you need to revert to the original or use the original somewhere else. Then you need to make a 2D sketch on the face for the cut, draw the appropriate profile, then "Extrude -> Cut" the part. Make sure you "Extrude -> Cut" rather than the default "Extrude -> Join". Double check your extents and selected profile. Once you have what you want, accept the preview and your part is modified.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 12-01-2016, 17:56
AKA: Chris Rollison
Thanks, as you said, for basic stock it took me far less time to just recreate it.
