Re: Imported STL Files
For simple stock shapes, you're probably better off making a new part, sketching the profile, and extruding to length.
If you really need to cut an imported part, first you'll want to save a copy just in case you need to revert to the original or use the original somewhere else. Then you need to make a 2D sketch on the face for the cut, draw the appropriate profile, then "Extrude -> Cut" the part. Make sure you "Extrude -> Cut" rather than the default "Extrude -> Join". Double check your extents and selected profile. Once you have what you want, accept the preview and your part is modified.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Reason: typo
