Go to Post Why silence the rude ones and naysayers when you could have the students learn to deal with them? - JackG [more]
Unread 19-01-2002, 10:53
schitnis schitnis is offline
schitnis is an unknown quantity at this point
Question Robot Speed
Zoom Zoom Zoom
How fast can a robot weighing 70 pounds, running on 1 atwood motors and 2 wheel drive, central stering system?
Has anybody done with locomotion of the robot ?
Regard
schitnis
Team 915
Unread 19-01-2002, 16:58
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Re: Robot Speed
Originally posted by schitnis
Zoom Zoom Zoom
Regard
schitnis
Team 915
While that seems like an easy question it's fairly complicated. First of all, is there any gear reduction in the drive train? Second, how much traction does the robot have? What size wheels are being used? How much inertia is felt by the motor (this will cause the motor to reduce speed)? So it's not a simple question. You can get a fairly accurate number by dividing the no load speed of the motor by two, and then factoring in the gear reduction and then multiplying by the circumference of the wheels. That will be a fairly accurate top speed if a bit on the high side.
Matt
Unread 19-01-2002, 17:46
Joseph F Joseph F is offline
#0506 (Steel Friars)
Joseph F is an unknown quantity at this point
Send a message via AIM to Joseph F
to much math for me. suffice to say its slower than using 2 atwoods on 2 drive wheels with a dual caster front... and more complex to engineer.
One Team, One Bot, One Fleet of Ambulances!
Unread 20-01-2002, 03:12
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
how fast is a segway?
oh wait...u said one motor...shucks...
lets see dean engineer that one!!
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 20-01-2002, 05:32
A 130 lb robot might do 3 m/s, but not push a goal, but a goal pusher might be unwise to try to go that fast, because the torque requirements are greater.
If you calculate it will go zoom-cubed, be prepared to change gears if the circuit breakers go click-squared.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
how would U determine the exact speed of your robot? HolyMasamune General Forum 4 29-01-2003 09:44
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
