Go to Post To me, every robot is a moving mechanical art form, a sculpture made of aluminum, motors and gears, and I think that soon we will be seeing those art forms involved in some of the most fantastic robotic "dances" that any of us have ever seen - DougHogg [more]
Unread 12-01-2016, 15:18
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Drawbridge Door Contact Question
I know for a crossing of the Drawbridge to officially count, a robot in the neutral zone not touching any component of the outer works must cross completely through the obstacle into the Courtyard. Also, it's legal to use teamwork to hold the drawbridge door down for another robot to cross through.
Can anyone say for sure if the following maneuver is regarded as a Drawbridge crossing (before I ask in the GDC):
Cross a different obstacle into the opponent courtyard, drive through the Drawbridge from the back (driving back into the neutral zone, but using an extrusion to hold the door open), then "tapping" the Drawbridge door into the ground (which will instantaneously lose contact with the arm and entire robot), then simply driving back through the Drawbridge obstacle to claim an entry?
I don't see a rule stating that the drawbridge door must be fully closed or a certain amount of time must pass between obstacle contact to declare it to be the start of a Crossing.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 12-01-2016, 15:27
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Drawbridge Door Contact Question
so far, so good
Make sure you comply with "completely in the Neutral Zone", so the part your "tap" needs to be the portion of the door in the neutral zone.
IMHO: If you are going to employ that strategy, then you better warn the Refs in advance so that they will look for it.
Unread 12-01-2016, 15:44
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
I was also planning on asking a Q and A question about how long you need to not be in contact with the defenses for.
Unread 12-01-2016, 15:46
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
We're thinking about trying this as a self-drawbridge/sally port crossing. I think better than tapping is having your extension out to catch the drawbridge. Drive off it, drawbridge swings up, catch with the extension and push it down to drive back. It's probably a little slower, but it's a lot more obvious you're not touching the drawbridge if it's free-swinging upwards.
But yes, you'll definitely need to warn the refs for the first few matches. Though if this is legal, I think it'll be common enough that they'll just watch for it rountinely.
Unread 12-01-2016, 16:24
This seems hacky. I'd amend the rule/blue box to look something like this:
When a ROBOT passes from their opponent's COURTYARD to the NEUTRAL ZONE through a defense in GROUP C, the spring assisted door must either return to its original position or have its motion impeded by an ROBOT of the same ALLIANCE
Unread 12-01-2016, 16:36
nuclearnerd's Avatar
nuclearnerd nuclearnerd is offline
Speaking for myself, not my team
AKA: Brendan Simons
FRC #5406 (Celt-X)
nuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant futurenuclearnerd has a brilliant future
I agree. This would turn the Category C defenses from the hardest to the easiest obstacles - changing the flow of the game completely from the GDC intent (I imagine). That said, I'll be watching the QA closely about this.
Unread 12-01-2016, 16:45
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Tom's proposal doesn't "turn" anything, it's currently the rules as written (aside from the "tapping" the OP is proposing).
Unread 12-01-2016, 16:49
InspectorGadget1073's Avatar
InspectorGadget1073 InspectorGadget1073 is offline
Jedi Master
FRC #1073 (The Force Team)
InspectorGadget1073 is an unknown quantity at this point
Just a warning--It may be really hard to become entirely in the neutral zone (You cannot be in the volume above the ramp), so please be weary before employing this strategy.
"I'm a human entropy producer." ~Dean Kamen, Our Lord and Savior
Unread 12-01-2016, 16:57
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Not sure I read the rules that way. Do you have a reference for that? Here is the definition of the OUTER WORKS
an infinitely tall volume bordered by the GUARDRAIL, the SECRET PASSAGE, and 2 in. white gaffers tape (The OUTER WORKS includes the white gaffers tape, but does not include the GUARDRAIL or SECRET PASSAGE). It consists of a series of five (5) DEFENSES, five (5) PLATFORMS, and five (5) Shields arranged in a line across the FIELD and is designed to impeded the passage of ROBOTS and BOULDERS in to the COURTyARDS
Nothing about that indicates that the open ramp is included in the volume of the OUTER WORKS. Therefore, that space should be in the NEUTRAL ZONE.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 12-01-2016, 16:59
AKA: Brendan Simons
FRC #5406 (Celt-X)
Heh. OK, but I smell an unintended consequence of a poorly written rule. I wager they'll change it (but we will happily play the door tapping game if not).
Unread 12-01-2016, 17:02
AKA: Josh P.
Sorry, I misinterpreted, I though "this" in your post meant Tom's interpretation/the-current-rulebook-besides-tapping, implying being able to "follow each other through" the doors would be game breaking. I also think tapping is silly.
Unread 12-01-2016, 17:10
dieDoktor dieDoktor is offline
AKA: Kipling Cohen
FRC #4118 (Roaring Riptides)
dieDoktor is an unknown quantity at this point
Where does it say this? The manual says that:
A DEFENSE is CROSSED by a ROBOT when that ROBOT
■ starts free of contact with the DEFENSE and completely in the NEUTRAL ZONE
Since the Drawbridge door extends down into the NEUTRAL ZONE, once you are clear of contact, you're good to cross.
Unread 12-01-2016, 17:27
Jared Russell's Avatar
Taking a year (mostly) off
I think the referees have more than enough to keep track of this year as it is. Expecting them to reliably see ~100 millisecond long gaps in contact with a door is asking too much.
Unread 12-01-2016, 17:47
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Just to add more to reinforce the above, there's a "blue box" which explains the GDC philosophy on this matter (end of section 3.1.3):
If it is unclear whether a ROBOT has satisfied the requirements for
CROSSING or REACHING a DEFENSE, the REFEREES are instructed
to not award credit. As such, DRIVE TEAMS should make it very clear
that their ROBOT has met the criteria for CROSSING or REACHING a
DEFENSE.
If it's unclear, no credit. I'm no lawyer (although I've been accused of being one in FIRST rule interpretation), but the originally-described approach seems pretty "unclear" to me.
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 12-01-2016, 21:20
Jedi Master
I interpreted this since that the OUTER WORKS is infinitely tall zone and the robot cannot be in this zone and completely in the NEUTRAL ZONE at the same time. I assume that the ramps are part of the OUTER WORKS also.
