Go to Post Iteration is a necessary but not sufficient criteria to being a powerhouse team. - Chris is me [more]
Unread 12-01-2016, 19:12
dharg99's Avatar
dharg99 dharg99 is offline
FRC #4633
dharg99 is an unknown quantity at this point
New radio
So my team got our new radio, only problem is it doesn't glow on any of the LED lights including the power. It makes electrical white noise so I know it's getting power... Trust me it's plugged into the right spot as the old d link worked in the exact same spot. Not the wire either, d link works on it too.
#4633Lyfe
Unread 12-01-2016, 19:14
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
Re: New radio
So what exactly are you asking?
-Michael Dessingue
Unread 12-01-2016, 19:16
thatnameistaken thatnameistaken is offline
AKA: Joshua Johnston
FRC #2191 (Flux Core)
thatnameistaken is on a distinguished road
Re: New radio
It doesn't go in the same spot. Plug it into the 12V 2A rail of the VRM.
Source
Unread 12-01-2016, 19:21
dharg99's Avatar
FRC #4633
New radio
I'm asking if I have a faulty radio.
Does it instantly begin to glow when plugged in or does it initialize? On either rail?
#4633Lyfe
Unread 12-01-2016, 19:23
epylko epylko is offline
Mentor!
AKA: Eric Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 1970
epylko is an unknown quantity at this point
Re: New radio
We don't know if you have a faulty radio. You plugged it in to the wrong power rails. Correct that and let us know how it goes.
Unread 12-01-2016, 19:24
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: New radio
Originally Posted by dharg99 View Post
...Trust me it's plugged into the right spot as the old d link worked in the exact same spot. ...
This might be your problem. See the picture below from the RQBS instructions. Notice it says "This is not the same place as the 2015 radio"
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 12-01-2016, 19:25
dharg99's Avatar
FRC #4633
Will do tomorrow, had to go home
#4633Lyfe
Unread 12-01-2016, 19:26
dharg99's Avatar
FRC #4633
New radio
Thanks guys, most likely is the problem...
#4633Lyfe
Re: New radio
It glows instantly IIRC, but make sure you're in 12V. You stated earlier that it's plugged into the same spot as last year, which is incorrect. If you're using last year's VRM, the new radio should NOT be plugged into the spot labelled 'radio power'.
Edit: Mega ninja'd. Dang mobile.
Unread 12-01-2016, 19:27
dharg99's Avatar
FRC #4633
Thanks
#4633Lyfe
Unread 13-01-2016, 19:53
dharg99's Avatar
FRC #4633
Hey it works
#4633Lyfe
