Go to Post FIRST is about so much more than what happens on the field, and sometimes we forget that. - Lil' Lavery [more]
Unread 12-01-2016, 19:40
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
After rebooting RoboRIO, no robot code until restart code.
This seems like a strange issue but,
When ever I boot up the robot and connect to it, the driver station says that that teleop is disabled for a second then crashes and says "no robot code". However, if I restart the robot code I can enable teleop with no problems and drive around.
I have updated everything to 2016 code and have a nav6 running on the roboRIO over USB using the navX library because the nav6 code is not ported yet.
Here is the console log (very minimal no obvious errors.)
Warning  44002  Ping Results:  link-GOOD,  DS radio(.4)-bad,  robot radio(.1)-bad,  cRIO(.2)-bad,  FMS-bad FRC:  Driver Station ping status has changed.  Driver Station
Warning  44002  Ping Results:  link-GOOD,  DS radio(.4)-bad,  robot radio(.1)-bad,  cRIO(.2)-GOOD,  FMS-bad FRC:  Driver Station ping status has changed.  Driver Station
 ➔ Launching «'/home/lvuser/FRCUserProgram'»
Warning  44003  FRC:  No robot code is currently running.  Driver Station
 AHRS Constructor!
 [HAL] Starting task FRC_navX-MXP_IO...
 Robot init!
 [HAL] Starting task FRC_DriverStation...
 driveBaseSub constructor!
 NT: server: client CONNECTED: 172.22.11.1 port 57018
 FWC Constructor!
I've never seen this happen? Any suggestions?
Thanks.
