Go to Post Wow, I am beginning to feel like a member of the fabled "vast right-wing conspiracy" :) - Jim Zondag [more]
Unread 12-01-2016, 15:56
Evelyn1123 Evelyn1123 is offline
Evelyn1123 is an unknown quantity at this point
Category A Crossing?
Most of B, C, and D obstacles can be solved with a tank drive, but these two seem a bit annoying. Any suggestions?
Unread 12-01-2016, 16:20
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
Re: Category A Crossing?
First: Don't underestimate the "easy" defenses. I guarantee that they will get folks stuck consistently through the season... Spend time prototyping and getting them right.
Second: Some of those others will require simple manipulators to lift/pull/etc.
Unread 12-01-2016, 16:25
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Or, teamwork. Even if your team doesn't have effective manipulators for everything, good driver communication can still breach defenses.
For example, Robot A (which could be the base kitbot) goes under the low bar into the courtyard (incidentally weakening the low bar), then opens either the drawbridge or sally port. Robot B then goes bumper-to-bumper with Robot A and they both drive through to the courtyard. Robot B has crossed the defense and weakened it. Sure, you would have to do it twice, but you don't need a manipulator to cross the sally port and drawbridge. It just might take two robots.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 12-01-2016, 16:28
What about the portcullis and the Cheval-de-Frise?
Unread 12-01-2016, 16:45
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
you just need an arm or two to push the cheval's ramps down and hold them down till you get wheels on them. Depending on how tall you are, you could use the same arm for lifting the portcullis. Main thing on the portcullis is lifting it enough to start going under, then having a smooth surface on top of your robot for it to slide over.
Unread 12-01-2016, 17:06
FRC #6357
Or, if you are sufficiently short, all you need is a wedge to lift the portcullis over your robot as you drive under it.
FLL Mentor 2006
FRC 619 Mentor 2002
Unread 12-01-2016, 17:15
ASD20's Avatar
ASD20 ASD20 is online now
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
My team is attempting to be able to do all of the defenses because we are concerned about this happening and another robot blocking one of the defenses. I predict that there will be a lot of teams that discover that their robot cannot go over the B and D defenses for the first time at competition.
Unread 12-01-2016, 17:19
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
I'm with Kevin. A single arm that moves up and down in front of the robot from near ground level to the height of all the fixed parts of the robot can push down one panel of the CDF, letting you drive over, and push up the Portcullis, letting you drive under. Details are left as an exercise. (We're still working out details!)
Edit: A skid plate may help on the CdF.
Unread 12-01-2016, 17:35
One of my partners in crime pointed out that pushing down two CdF ramps and driving over those may be better, so you don't have to worry about the skid-plate issue.
Unread 12-01-2016, 17:45
InspectorGadget1073's Avatar
InspectorGadget1073 InspectorGadget1073 is offline
Jedi Master
FRC #1073 (The Force Team)
InspectorGadget1073 is an unknown quantity at this point
I suggest using a mechanism that can:
1. Lift the Portcullis
2. Press down one ramp on the Chival de Frise
3. Pull down the Drawbridge
4. Open the Sally Port
5. Scales
This can all be achieved with a mechanical arm that moves up and down from a pivot point on the robots frame, and has two hooks on the end, so that you have a hook facing each way. I would also extend for the portcullis and scale, and with some mechanical genius, it will do all of this. I hope this helped with your robot.
"I'm a human entropy producer." ~Dean Kamen, Our Lord and Savior
Unread 12-01-2016, 17:57
Kartoffee Kartoffee is offline
FRC #2834
Kartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to allKartoffee is a name known to all
Our team just decided that "French" was the better name for the Cheval de Frise. As in, "our robot can handle French pretty easily".
Unread 12-01-2016, 19:50
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
My thought for category A was to breach another defense, then come at these the other way and push them open, then you just need to drive back through while your bot is still holding them open. I don't see why this wouldn't work.
Robots + Python + pentesting == me;
Blog ~ GitHub ~ Keybase
If you have a pressing issue to discuss with me, kik me at slush.puddles since I don't check CD very often.
Unread 12-01-2016, 19:54
I do. Take a look at the definition of Crossing, and you'll notice that the first element is that you NOT be in contact with the Defense.
Unread 12-01-2016, 21:39
Also, you're thinking of the drawbridge and sally port which are category C.
Unread 12-01-2016, 21:42
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
"Frenchie" might be better.
