Go to Post The only way you can be undermined is if you let yourself be undermined. - DUCKIE [more]
Unread 12-01-2016, 17:23
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
Single or 2 speed gearbox?
I have looked through the game and came up with my own version of a robot that I would find optimal. Except the only thing I am on the fence about is the drive gearbox.
I can see using a single speed geared toward 11 fps for simplicity and compact design but I can also see a 2 speed for getting over things fast while low gear is for pushing and if the robot gets stuck on a defense.
(Optimally a 7 fps and 17 fps 2 cim gearbox)
What are your options on a particular gearbox design and what is your team most likely doing?
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
Unread 12-01-2016, 17:42
aldaeron aldaeron is offline
AKA: -matto-
FRC #1410 (Kraken)
aldaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond reputealdaeron has a reputation beyond repute
Re: Single or 2 speed gearbox?
I'll ask you the same question I ask my students
What is the tradeoff between 1 and 2 speed gearboxes? What about 2 vs 2.67 vs 3 CIMs per side?
Unread 12-01-2016, 23:24
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Single Speed Double Reduction from Vex, 12:57:1 ratio. They worked great for our Ri3D drivetrain. I don't see the benefit of shifting vs. the volume/weight for FIRST Stronghold. If you decide to go for a low robot <16" fitting ball shifters on the drivetrain is a pain.
