Go to Post Defense shall reign supreme. - Corey Balint [more]
Unread 12-01-2016, 23:37
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Versa gear box
Having a problem trying to find out the force required to back drive a versa 2 stage box.
Plan would be bag motor driving a 2 stage box first and second stage at 10:1 giving an overall 100:1 with 1/2" hex output.
Also anyone know what the no load speed would be?
Unread 12-01-2016, 23:43
Re: Versa gear box
If you're thinking of using it to hang, the answer is "not enough". Planetary gearboxes as a general thing take a lot less force to backdrive than you might think. 150 lb of robot will probably do the trick as far as backdriving that. It won't be the easiest thing in the world to get going, but it will probably get going eventually.
BTW, the no-load speed is the BAG no-load speed/100 (and the output torque is the BAG torque*100), assuming a perfectly efficient gearbox.
If you're thinking of hanging with this, I'd add some sort of braking device to the output.
If you're not attempting to hang, the important part is that second paragraph about the no-load speed.
Unread 12-01-2016, 23:44
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Versa gear box
if by speed you mean RPM then you'd get 14 000/100 = 140 RPM (Vex's specs says =/- 10%)
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 13-01-2016, 00:07
dradel's Avatar
Wouldn't be hanging. Would be using to vary the angle of an arm on the bot. Was trying to figure out how much force would take to back drive. Imagine if you will having a hub on the output shaft that had say a 20" bar attached to the hub. The bar would be raised and lowered from below horizontal and also above horizontal. What amount of weight could be placed along the length of the bar before it would back drive ?
Unread 13-01-2016, 00:10
Charding18 Charding18 is offline
FRC #3039
Charding18 is an unknown quantity at this point
Re: Versa gear box
So basically it would be unwise to use the 100:1 versa gearbox to use as a winch to climb? Is it not strong enough to lift the robot or does it just have a lot of slippage?
Unread 13-01-2016, 00:13
Re: Versa gear box
It's the slippage. Remember that the robot does have to stay up at the end of the match for the Scale points.
Whether it's strong enough or not depends a lot on what motor you've got going into it and what you do with the output as far as gearing/winching.
Unread 13-01-2016, 00:21
Ginger Power's Avatar
Ginger Power Ginger Power is offline
The GreenHorns Team Lead
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Ginger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond reputeGinger Power has a reputation beyond repute
Re: Versa gear box
This is the exact same setup that The GreenHorns have for our winch. We used the hex output shaft to drive a 1 1/2" pulley by press fitting a versa hub inside it. It would get us 21" off the ground before really struggling and eventually stalling. The pulley was about 3 inches wide so the pulley grew in diameter as it wound up. The JVN calculator said it should take about 5.5 seconds for it to winch us up to that 24" mark.
I'd recommend a smaller diameter pulley than 1.5" because that's pushing the limits. Another thing to note is that out robot weighed only 86 lbs with the battery and without bumpers. A single bag motor at 100:1 is pushing it I think. It would suck to have an underpowered winch.
Mixing and matching the motors/gearboxes/gear ratios to get that winch to lift the robot in under 10 seconds was fun. Like trying to solve a puzzle (however we didn't have all the pieces i.e. gearboxes at our disposal).
Edit: Also, we didn't experience any backdrive when our robot was in the air. Again, it was only 86 lbs.
Unread 13-01-2016, 00:24
FRC #3039
Re: Versa gear box
So if we use two of the 100:1 gearboxes it should, in theory, cut the load in half for each motor? Instead of the one motor picking up the whole 120lbs, with two motors, it would only be lifting 60lbs, right?
Thus , cutting the time in half to raise the robot?
Unread 13-01-2016, 00:32
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Re: Versa gear box
2 bag motors each in a 100:1 versa planetary would have plenty of power from the testing that we've done. The combined motors would in fact have double the power, but having both would allow you to winch faster if you wanted at the sacrifice of power. With that much power you'll have the luxury of optimizing speed and power.
Unread 13-01-2016, 00:34
FRC #3039
Re: Versa gear box
Thanks so much. I just wanted to make sure that it could possibly work. I think this may be the way to go for our robot.
Unread 13-01-2016, 00:39
dradel's Avatar
Now that the thread has been hijacked..... Anyone have an idea on the force to back drive with a 20" bar on it?
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
Re: Versa gear box
Will you get the same effect will two BAGs in an adapter to one versaplanetary 100:1 or is there something about that setup which would not be suggestible?
Unread 13-01-2016, 01:00
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Re: Versa gear box
Sorry, questions arose that were related and I felt the need to respond since it was something I literally just got done with As for the amount of force to back drive a 100:1 versa with a 20" bar... there's some math the be done. I can't speak to that situation specifically, but we ran another 100:1 versa planetary with a cim in it to control our articulated shooter. We used a 48 tooth gear on the hex output shaft to drive another 48 tooth gear (the geometry just worked nicely). The friction in the gearbox was just barely less than what we needed to stall our shooter at a horizontal position. The arm weighed around 12-15lbs and was 15" long. If I had to estimate the ditance from CoG to the output shaft I'd say it was 12".
Hope that gives some sort of reference.
Unread 13-01-2016, 01:04
AKA: Ryan Swanson
FRC #4607 (C.I.S.)
Re: Versa gear box
That's a good question... adding an adapter and another motor will introduce more inefficiencies to the gearbox, but you'll have double the power. I've never used a setup like this, but 1 bag motor is close to the necessary power, so adding a second should give you a nice factor of safety. This will be nice especially given that you'll be climbing when your battery has been used for a whole match.
Unread 13-01-2016, 01:22
dradel's Avatar
No problem. Did you guys direct drive the wheeled shooter with cims? They may be mini sims hard to tell on YouTube
