Go to Post FIRST is like pizza--you and I might prefer different toppings, but there's no wrong way to do it. - Billfred [more]
  #31   Spotlight this post!
Unread 12-01-2016, 13:28
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Re: Immobile 200+ pts solo robot concept
Originally Posted by TimTheGreat View Post
Not quite. G11 states that the opposing alliance cannot force a robot to break a rule. So if they touch you it's not a foul on you. In fact, it's a foul on the OTHER team.
No, that is not what G11 states. This is what G11 says (emphasis added):
Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FIRST Robotics Competition and not allowed.
Bumping into someone in your secret passage is not a "strategy." No momentary game event is a "strategy." You have every right to drive around in your secret passage, and if someone is in your way you have the right to bump into them.
A lot of people are over-interpreting G11 in this way, and some of the previous posts have done a good job of showing how absurd that interpretation is. Combined with G21, that means that if two robots on opposite alliances hit each other in a secret passage, whichever one initiated the contact gets a foul, which will often be impossible to judge, and clearly goes against the intent of G21, which is written to only apply to members of the opposing alliance. That's not to mention the infinite descent of "well you caused me to cause you to foul me, so you violated G11 by forcing me to violate G11," and so on ad absurdam. Any interpretation of the rules that results in infinite recursion is clearly flawed.
The intent of G21 is clearly that robots in the opposing team's secret passage have to make way for opposing robots or get a foul. The opposing team does not have to have a justification for doing so--it's their own secret passage, they can do what they want in it!
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
  #32   Spotlight this post!
Unread 12-01-2016, 15:48
Case0823 Case0823 is offline
FRC #2358
Case0823 is an unknown quantity at this point
I had a similar thought on this strategy initially.
I also found that I had misinterpreted the field drawing as to whose secret passage is whose, due to the different flags in different drawings being visible. That topic is covered in another thread.
The point is that the secret passage you'd need to sit in or by, is controlled by the other alliance. Therefore if you are contacted by their bot when they try to receive boulders you will most likely be penalized. It also means that the other alliance controls when and how those boulders are put back onto the field. This will limit your points. AA year proved how a nicely timed bump can cause a miss with a long shot. Therefore I do not think this will be a high scoring strategy for very long if at all.
It worked better for Frisbees since you controlled most of the variables.
It's technically feasible with the current rules but very risky. This also depends on the interpretation of the blockade foul.
  #33   Spotlight this post!
Unread 12-01-2016, 23:58
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
We discussed the Choke-hold robot idea today, and we see 2 flaws with it:
The first flaw is debatable: Intuitively, this is not the way the GDC intended the game to be played. The reason you should care is that they have the ability to change the rules at any point, including AFTER build season. (see HighRollers in 2008 for an example of this)
The second flaw is a bit more powerful. Consider Rule <G4> (emphasis added):
DRIVE TEAMS may not extend any body part into the FIELD during the MATCH.
Momentary encroachment through the hole in the HUMAN PLAYER STATION behind the BRATTICE while placing a BOULDER into that hole is an exception to this rule.
Violation: FOUL. Violations of this rule are likely to escalate to YELLOW or RED CARDS rapidly (i.e. the threshold for egregious or repeated violations is relatively low)
Blue Box:
Examples of egregious violations include, but are not limited to, walking onto the FIELD during a MATCH or intentionally reaching into the FIELD and grabbing a ROBOT during a MATCH.
Our interpretation of this is that a human player may insert his hand into the BRATTICE while holding the ball, and then throw the ball UP and possibly also diagonally. The ball would most probably not enter into the choke-hold robot, and the strategy defeated.
The height limit means that the robot can't block the brattice, so this would always be possible.
Thoughts?
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
  #34   Spotlight this post!
Unread 13-01-2016, 00:02
AndyBare AndyBare is offline
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
-Leav
The rule does say "placing." More specifically, if you want to dive beyond that., "placing... into that hole." I think that kind of firms things up a bit.
Andy Bare
Team 1261
  #35   Spotlight this post!
Unread 13-01-2016, 00:09
EricH EricH is online now
The other problem with this concept is TU#1... If there's somebody parked down there, and their bumpers don't match the berm, they need to run if somebody else comes in!
  #36   Spotlight this post!
Unread 13-01-2016, 00:16
Leav's Avatar
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Only if they are touching the carpet, if I understand correctly. it's possible (probably) to execute the choke-hold strategy without touching the carpet in the secret passage.
-Paraphrasing JFK
