Go to Post the few, the proud, the animators. - BuddyB309 [more]
Unread 15-04-2015, 07:30
Arhowk's Avatar
Arhowk Arhowk is offline
FiM CSA
AKA: Jake Niman
Re: Javascript Robots!
I'm down as well (I was actually planning to do JavaScript this season but the teams member count was really low so I had no time).
Stuff that would need to be done
1) WPILib for JavaScript
2) JavaScript interpreter for the roborio (Java has on built in, there are some good cpp ones available)
3) sample projects
4) code development tool, preferably cross platform (recommended javafx or Qt)
5) rio tools (flasher If necessary, code dashboard, JavaScript rio interface)
6) code deployment tool
7) debugging tools
8) (optional) Js native interface tools (for running hard vision processing loops, sensor feedback loops, etc)
I'd be interested in learning Qt if there were enough other people to support the rest of the project (else I'd do something simple like a ftp server attached to sublime)
Unread 15-04-2015, 10:00
michaelwm's Avatar
michaelwm michaelwm is offline
Integrated Systems Lead
AKA: Michael Midura
FRC #4976 (Rebel Robotics)
michaelwm is a jewel in the roughmichaelwm is a jewel in the roughmichaelwm is a jewel in the roughmichaelwm is a jewel in the rough
This was a small side project for me this year, and i'm finishing it during this offseason. Some useful things we learned that anyone interested in using javascript for their robot:
Don't use Java 8 / Nashorn (their built in JS interpreter):
  • The initial build of Java 8 installed on the roboRIO does not include Nashorn (or any JS interpreter for that matter). See here.
  • It grows exponentially slow. Just printing "hello world!" executes fine. The more code we added, the slower it's execution time got. Any function (releasing a cylinder, driving a motor) took upwards of 5 seconds to execute.
Have an intuitive software design
  • We based our JS design off of the DOM webdesign convention. Driving a motor in JS is as simple as
    robot.talon.port3.set(1);
    (Subject to change as we refine our programming model)
  • Aside from being interpreted in real time, JS is the most common language taught in high school programming courses. If you ever want new programmers, an intuitive design based on what students already know (DOM) will attract new programmers like crazy.
Our team is using the Google v8 JS engine (the same engine powering node), and we have had major success. We will be releasing the source soon, but I personally would love some competition!
Integrated Systems
Unread 15-04-2015, 16:35
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
O.O
How exactly are you doing this...? Assuming you're just throwing the talons inside of a SimpleBinding, 5 seconds is absolutely monstrous. Are you doing something wierd like interfacing with the HAL layer directly from JavaScript?
Unread 15-04-2015, 19:31
michaelwm's Avatar
AKA: Michael Midura
Originally Posted by Arhowk View Post
O.O
Not at all actually, we were passing the Talon, Solenoid, and other classes directly to the scripts as variables, and the scripts simply called their methods (i.e. Talon.set(n). The problem is with the amount of scripts / the length of scripts. If your program had just a single script that said
talon.set(1)
, it would execute fine (but is entirely useless). The more scripts and the longer the scripts are, the longer it took for the interpreter to parse them, and call their methods, thus the 5 second execution time.
We're switching to v8 because it utilizes JIT compilation. We are using the roboRIO's file system to store scripts, and the program compiles them at startup (during queue, for example), and never touches them again, unless our development mode is active. In this case, an external file watcher on the development machine watches for changes to javascript files, and when it detects one, sends the changes to the roboRIO, which stores the new file on the File System, and recompiles it. This minimizes execution time to instantaneous during competition (as no compilation is done during a match because no development is active), and much shorter times than the current java/c++ compilation times for WPI/eclipse.
Integrated Systems
Unread 15-04-2015, 19:43
JesseK's Avatar
JesseK JesseK is online now
Expert Flybot Crasher
FRC #1885 (ILITE)
If you're talking about intuitive design, Talon's don't have 3 ports - PWMs do. It'd get particularly sticky if you had to do Talon SR vs SRX vs SP. I'd recommend doing robot.pwm.port3.set(1), then at instantiation determine what port 3 actually is and make sure that object has a set() method.
Unread 16-04-2015, 11:27
Arhowk's Avatar
FiM CSA
AKA: Jake Niman
I don't know if the roboRIO does this but I know you couldn't with the sidecar because jaguars and talons/victors took different PWM wavelengths. The most intuitive would be something like this
robot.elevatorMotor = robot.pwm.port3
or, if you have to
robot.elevatorMotor = HAL.getMotor(3)
Unread 16-04-2015, 12:00
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
or, if you have to
Correct, there isn't a way for the program to determine which type of PWM device is attached to it, so if you were to use this notation then the user would need to provide some declarative configuration that indicates what device is at which port.
The robot.pwm.* or robot.port* notation is interesting, but it's probably mostly useful for retrieving objects, instead of actively using them that way. Consider 'robot.arm_motor.set()' vs 'robot.pwm.port2.set()' -- if you ever change what port your arm motor is attached to, then you'll have to change it everywhere in code if you use the second notation everywhere.
However, it could be a more useful way to create these objects. Maybe something like robot.pwm.port2.createTalon('arm_motor') automatically creates a robot.arm_motor attribute.
Unread 16-04-2015, 20:46
bthlx bthlx is offline
FRC #3223
bthlx is an unknown quantity at this point
Hi all, I just saw this thread and got super excited.
I've been wanting a JS alternative since I started doing FRC 3 years ago.
I was thinking it'd be fairly straightforward to implement RobotJS as a node add-on, but going with the v8 engine directly may be better. I was thinking it would be nice to use the built nide modules like fs if necessary so that was my attraction to the add-on route.
As far as syntax, couldn't you do something like:
var wpilib = require('wpilib');
var robot = new wpilib.IterativeRobot();
robot.liftMotor=new wpilib.Talon(1);
which is a very nodejs idiom.
Thoughts?
Unread 17-04-2015, 20:24
michaelwm's Avatar
AKA: Michael Midura
Thoughts?
There are 2 way's to go about this problem, a solution similar to Node, and a solution similar to DOM. Whichever way you choose, it shouldn't matter at all performance wise. We chose DOM, because the majority of new programmers are very familiar with DOM. If your programming team is more familiar with Node / classic programming markup, then your method is definitely better.
The great thing about using v8 directly instead of Node is that you get to choose your syntax and the way your programming team scripts it's robot. Go nuts!
Integrated Systems
Unread 13-01-2016, 00:21
duane's Avatar
duane duane is offline
FRC #0701 (RoboVikes)
duane is an unknown quantity at this point
Send a message via AIM to duane
Resurrecting an old thread.
Did anything come of this project? I'd be interested in helping or taking a look at how it turned out.
Duane Murphy
Mentor - Software
Vanden Vikings FIRST Team 701
http://www.vandenrobotics.com
Unread 13-01-2016, 10:21
Jaci's Avatar
Jaci Jaci is offline
AKA: Jaci R Brunning
FRC #5333 (Can't C# | OpenRIO)
Rookie Year: 2015
Jaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond reputeJaci has a reputation beyond repute
Toast has support for the Oracle Nashorn JS engine, which integrates directly with the JVM. https://github.com/Open-RIO/ToastAPI
You can write your robot program in .js files and we provide some common hooks to things like motors, logging and other stuff
Jacinta R
Curtin FRC (5333+5663) : Mentor
5333 : Former [Captain | Programmer | Driver], Now Mentor
OpenRIO : Owner
Website | Twitter | Github
jaci.brunning@gmail.com
