Go to Post It's hilarious to watch this conversation about a box which probably has a 95% chance of being robot batteries turn into all kinds of bowling ball conspiracies. - artdutra04 [more]
Unread 12-01-2016, 21:49
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Category A Crossing?
Originally Posted by Kevin Sevcik View Post
One of my partners in crime pointed out that pushing down two CdF ramps and driving over those may be better, so you don't have to worry about the skid-plate issue.
Not on the way up, but perhaps on the way down. Not as bad as driving into the ramp, but it could still hit things on the undercarriage.
Originally Posted by Kartoffee View Post
Our team just decided that "French" was the better name for the Cheval de Frise. As in, "our robot can handle French pretty easily".
I've referred to it somewhere in writing as the CDF or CdF. I guess it's because I grew up in the Greater New Orleans area that saying Cheval de Frise isn't that difficult. Other than that, between D&D and a year in the SCA, I think that Batter is the the only term I didn't get straight away, and I'm guessing it's a cognate of Batture, which is a relatively high area between a river and it's natural levee, so that didn't take too much work.
Originally Posted by InspectorGadget1073 View Post
I suggest using a mechanism that can:
1. Lift the Portcullis
2. Press down one ramp on the Chival de Frise
3. Pull down the Drawbridge
4. Open the Sally Port
5. Scales
This can all be achieved with a mechanical arm that moves up and down from a pivot point on the robots frame, and has two hooks on the end, so that you have a hook facing each way. I would also extend for the portcullis and scale, and with some mechanical genius, it will do all of this. I hope this helped with your robot.
We're working on a mechanism that picks up, holds, and launches boulders, as well as the Portcullis and CdF (it uses the boulder as part of the manipulator). A second mechanism would handle #3 and #4. Scaling has moved to our back burner; it's 10 points per match, but it does not affect QP unless the 10 point differential changes the outcome of a match. Defeating at least four classes of defenses and getting those first 8 boulders are our #1 priority. Beyond that, boulders are an "infinite" source of points, while scaling is never more than 10 per match.
Originally Posted by The Doctor View Post
My thought for category A was to breach another defense, then come at these the other way and push them open, then you just need to drive back through while your bot is still holding them open. I don't see why this wouldn't work.
I do. Take a look at the definition of Crossing, and you'll notice that the first element is that you NOT be in contact with the Defense.
I fully concur with EricH, and was planning to post on this point this evening but this largely covers it. The point is that you have to enter the outer defenses NOT in contact with the defense. The teamwork plan may work with the sally port, but not the drawbridge unless you have an unusual angle of attack, probably including swerve or holonomic wheels. Not only have we decided not to do a fancy drive train this year, it's entirely possible that we'll go completely period on wheels and manufacture ours largely from wood planks. I love this game.
Unread 12-01-2016, 21:59
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Alternatively, "Our robot can French pretty well"
XD
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 12-01-2016, 22:21
droswell's Avatar
droswell droswell is offline
FRC #2370 (iBots)
droswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to beholddroswell is a splendid one to behold
Also, you're thinking of the drawbridge and sally port which are category C.
I believe it would be legal for you to hold the door for your teammates. Is this your interpretation as well?
Unread 12-01-2016, 22:36
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
As long as the robot doing the crossing does not touch the defense outside of the Outer Works, that should be legal.
Unread 13-01-2016, 00:25
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Originally Posted by jee7s View Post
Robot B then goes bumper-to-bumper with Robot A and they both drive through to the courtyard. Robot B has crossed the defense and weakened it. Sure, you would have to do it twice, but you don't need a manipulator to cross the sally port and drawbridge. It just might take two robots.
Why would you have to do it twice? The defense is fully weakened once both robots go through
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 13-01-2016, 00:33
Nope. Where did Robot A start? In the Courtyard. Where do you have to be to start a Crossing? In the Neutral Zone, NOT in contact with a Defense. How do you Damage a Defense? Two Crossings.
This particular Crossing method will only net you one Crossing, thus one "hit" to the Defense.
Unread 13-01-2016, 02:14
cbale2000's Avatar
cbale2000 cbale2000 is online now
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
Conversely, if you had all 3 alliance members cross at once you could eliminate that defense altogether in one go.
Personally I buy the argument that a mechanism could be created for both Category A defenses, I do not see, however, given the available expansion space and geometry of the Category A and C defenses how you could also open the Category C defenses without a second mechanism or some secondary actuation on the first mechanism.
IMO, since Category A is the only set of defenses that cannot be defeated by robot that can only drive, so prioritize mechanisms for those defenses first and if you have the extra weight after you're done, add something for Category C, otherwise just work with your alliance partners.
Unread 13-01-2016, 06:24
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
"Shovel de Fries" and say that weeeth a french accent just like a Pepe de Pewww.
Total apologies to our French FRC friends, just attempting some word association games....My last name? Lucier Yes, it is French.
Unread 13-01-2016, 06:32
FRC #0060
On a return trip I open Sally Port door, here move on in partner where you'll be safe, hold on I'll be right back...Do wait for me please (I return over another easy Defense, grab a boulder as I'm not going over empty handed), join you holding the door I opened for you from the neutral side, we proceed. Sally Port Damaged. Draw Bridge is next if it's there. While you wait for me you are safe...If not we'll pick up those penalty points later from them at match end.
Unread 13-01-2016, 06:51
engunneer's Avatar
engunneer engunneer is online now
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
There will be a drawbridge /or/ a Sally port. Never both.
Unread 13-01-2016, 07:34
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
In our game analysis we developed a match gameplan for three types of matches:
- Quals at district event (our robot and 2 minimally functional partners)
- Elims case 1 (us and 2 pretty good partners)
- Elims case 2 (us, 1 other excellent partner and one minimally functional partner)
In all three of these gameplans, the first two actions are:
1) autonomous drive across an easy defense (score goal if technically possible)
2) open door/drawbridge for partners to drive through
This ensures that seconds into teleop we will have a minimum of 20 points on the board and 3 of the 8 required defense crossings completed, even if our partners are only boxes on wheels that can just drive.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 13-01-2016, 07:43
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
Category A
Pork Cutlet (portcullis)
Cheese Fries (cheval de frise)
Category B
Root Beer Moat (moat)
Jam Tarts (ramparts)
Category C
Salad Fork (sally port)
Raw Cabbage (drawbridge)
Category D
Gumball (rock wall)
Hunger Pang (rough terrain)
Permanent Defense
Steak Tartare (low bar)
Hi!
Unread 13-01-2016, 10:05
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Originally Posted by GeeTwo View Post
Permanent Defense
Steak Tartare
Surely this defense is Chicken Paillard. Or is that not an option cause it's still French? Or maybe Tostones. The Panini Press? Oh! George Foreman. That surely has to be the correct name.
