Go to Post I am a big fan of community building exercises. And harassing my friends. - Amanda Morrison [more]
Unread 12-01-2016, 23:32
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
Re: Is anybody talking about the low bar?
Originally Posted by Sperkowsky View Post
(Linustechtips.com)
Brought to you by squarespace!
/s
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 12-01-2016, 23:43
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
/s
"Build it Beautiful!" said Luke
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 13-01-2016, 01:30
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
/s
Ah you guys know them.
Sad to say I barely watch the videos anymore or go on the forum. I do still talk to Luke(still slick to me) once in a while on teamspeak if I'm up at a weird time.
Unread 13-01-2016, 06:12
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Originally Posted by GeeTwo View Post
Our answer was YES, we need to be able to cross under the low bar. It's there every match, in the same location. It's ESSENTIAL for teams going after lots of boulder points (which is the only "unlimited" source of points), and still pretty important for teams playing for a sapper (focused on breaching defenses) function. I think most top 8 and first-pick alliances will fall into one or both of these two categories.
I would not be surprised if our initial configuration is more than 14-16" tall, but I absolutely expect us to have a configuration that will fit below the low bar while carrying a boulder.
Gus,
Where's the rule that your boulder has to pass through under the Low Bar just because your robot must? My idea alone (you'd need to check w/ the rule makers so you wouldn't be a rule breaker). As long as the robot maintained full control over the boulder during the entire traversing from beginning to end.....Long narrow low robot under the 120" frame limit, boulder gripper on the rear, boulder gripper on the front......Robot begins to pass under Low Bar and the drape and pole at bottom of drape, the rear gripper passes boulder to front gripper over the top bar of the Low Bar when about half way through, deposit in low goal or deliver to high goal shooter. As soon as the wheels hit the carpet completely (if there was a high goal shooter), it would be easy to pitch pass it to the shooter....zoom back for more ammunition.
The Robot never lost control of the boulder, and robot never went completely over the Low Bar as per the rule. Asked properly of the Q&A the answer may just surprise many of us. Three fingered simple ball grippers front one rotated 1/3 so the fingers fit together. Adjustable pneumatic.
Unread 13-01-2016, 07:08
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Originally Posted by cglrcng View Post
Gus,
Not a rule, but an optimization so we don't have to go acquire the boulder again.
Edit: We did not consider handing the boulder to ourselves, over the bar, but we may carry it outside the frame perimeter for the low bar crossing. We like simpler.
