Go to Post I dunno, with those Chucks, I'd be inclined to say he out-dresses the better part of DC... - Nuttyman54 [more]
Unread 13-01-2016, 10:23
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Macintosh problem - persisting wpilib settings
On some (maybe all) fresh Macintosh eclipse installs, we are having trouble persisting only SOME of the WPI lib settings.
The team number persists fine.
But the "Tools Version" value stays set after we apply / save it only until we quit eclipse.
When we re-start eclipse, Run as / deploy... fails until we check the value again (which is then empty); if we re-set the value to the correct value "plugins", things work again.
We would welcome advice as to what we're missing.
-suggestions as to which file we can over-ride
-it may be a permissions issue ...
Thanks,
Martin Haeberli
Mentor,
FRC 3045, Gear Gremlins
Unread 14-01-2016, 19:34
mpkirby mpkirby is offline
FRC #3181
mpkirby is an unknown quantity at this point
Re: Macintosh problem - persisting wpilib settings
We also have the same problem.
Running OSX 10.10.5 (Yosemite), with the Mars version of eclipse.
Mike Kirby
Mentor - Team 3181
