Go to Post changing some 0 to 1s was a lot lighter and cheaper than most of the clutches I found. - IKE [more]
Unread 13-01-2016, 10:19
Roboshant's Avatar
Roboshant Roboshant is offline
Design Lead 17, Scouting Captain 16
AKA: Dikshant Sharma
FRC #0226
Rookie Year: 2015
Roboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to allRoboshant is a name known to all
6 CIM + 2 mini CIM brownouts
If one runs a 6 CIM drive train whilst using a 2 mini CIMs for a separate mechanism conjunctively, would it be risking brownouts?
Unread 13-01-2016, 10:25
EmileH's Avatar
EmileH EmileH is offline
starting to feel the burn
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: 6 CIM + 2 mini CIM brownouts
The answer to this question is completely dependent on how much current you're drawing from each subsystem. If your 6CIM drivebase is using a lot of current - ie, you're pushing somebody and the drivebase is geared for a medium to high gear ratio (>10fps), while running 2 mini cims at full speed (but at free speed), yes, you may experience brownout. However, if not being pushed or not running your drive base too fast, you likely will not experience more than a momentary brownout when accelerating or turning as you drive. Do not take my word for this however - the best way to tell is to build it and test it - OR if you already have a similarly-geared 6CIM drive in your shop, just strap on 2 miniCIMs, run them at full speed and drive around, and see what the brownout characteristics are.
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 13-01-2016, 10:28
pfreivald's Avatar
AKA: Patrick Freivald
That's going to depend on how you're running them. You can risk a brownout (and definitely trip breakers) running one or two CIMs by themselves if you're near stall.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 13-01-2016, 10:36
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
While I agree that it's impossible to guarantee that you will or will not get brownouts, I'm going to go out on a limb here and say that it's a significant risk. If you plan on running these mechanisms at the same time, you should probably add some code that checks and regulates current draw.
You can also learn more about designing with motors and current draw here
Cim motor curve: http://motors.vex.com/cim-motor
And mini Cim motor curve : http://motors.vex.com/mini-cim-motor
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
Unread 13-01-2016, 11:16
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
We've run six CIM drives quite successfully a few times, but we do struggle with brownouts when we do... We've found that if we require that much power in a drive train, we really need to limit the number of other tasks our circuits must handle... Pneumatics help a lot... We find that, when we need that much power, 4 CIMS, a drive system with good traction (6 wheel tank?) and a two speed gear box gets us plenty far... That allows us to be a bit more creative with our manipulating functions.
