Go to Post Big scoop for everyone here: All divisions are stacked with talented teams. It's like this is a really big event or something. - PayneTrain [more]
Unread 13-01-2016, 11:10
MAXOFLIFE's Avatar
MAXOFLIFE MAXOFLIFE is offline
Bolton Bear Bots Member
AKA: Maxwell Huffman
FRC #3666 (Bolton Bear Bots)
MAXOFLIFE is an unknown quantity at this point
What is the metal bar in this picture specifically named?
Sorry for a such a simple question, but one of the biggest hurdles my team has to worry about is specific names for mechanical and electrical components when we can't find a serial number or something similar.
What are the beams that are holding these two tread's together called? We ordered a set of treads from AndyMark and want to have everything we need to set them up when they arrive.
(Edit: Image was too big)
It's the picture under the More category.
http://www.andymark.com/Rhino-p/am-3322.htm
Thank you for your time and help! Is there a better forum to ask questions like this on for future reference?
Unread 13-01-2016, 11:14
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
Are you talking about the Rev extrusion? Or are you talking about the turn buckles?
If it's the Rev extrusion I would stock up on mounting hardware. They use lp 10/32 nuts I believe which are hard to find. Andymark sells the bolts and nuts. Buy the nuts from them but I would buy the bolts from somewhere else as they are more easily found for cheaper and the Andymark ones strip really easy if you use a drill.
Unread 13-01-2016, 11:51
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: What is the metal bar in this picture specifically named?
Are you referencing the turn-buckle? Basically, a threaded extrusion with eye hooks on each side, useful for providing length adjustment.
2016: Lake Superior WFFA
Unread 13-01-2016, 12:28
Chris is me's Avatar
AKA: Pinecone
Nuts are used to mount things into the T-slots of the REV extrusion, not to mount to the ends. To mount to the ends of the extrusion, one either taps the center hole for 1/4-20 or uses a #10 bolt through the entire piece of extrusion.
Unread 13-01-2016, 13:04
Sperkowsky's Avatar
I know sorry was not clear.
Once the chassis is built you have to interface with it so that's why I recommenced buying some brackets and hardware.
Unread 13-01-2016, 13:08
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
Kinda unclear which parts you are asking about but the circular-looking things are called churro.
http://www.andymark.com/product-p/am...m?1=1&CartID=0
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
