Go to Post There are no simple solutions, as every solution has its own problems. - M. Lillis [more]
Unread 13-01-2016, 12:02
Farbod909 Farbod909 is offline
FRC #1515
Farbod909 is an unknown quantity at this point
Re: 2016 Scouting Ideas/Apps
Yes! MorScout 2.0 is a perfect solution for you. It can be used offline or online so you have that freedom in case internet is not working in the arena. Also, you can fully customize your scouting forms so you're not restricted to team 1515's scouting strategy (however, that will still be an option).
Here is the full description:
Team 1515 MorTorq is developing the next iteration of our scouting application, MorScout, from last year. Our scouting application is designed to be run without any setup, meaning your clients will require an internet connection to login and periodically to sync to the server. MorScout is designed to run primarily on Android and iOS, but also web browsers. Each FRC team can create accounts for their own scouters. Our application is designed for both match scouting, as well as pit scouting. Each team can create custom forms for their scouters to fill out, so teams are not limited by just our scouting ideas! Once scouting reports have been made, team members can view all reports from their team for specific matches and/or teams. Additionally, scouters will have the option of making their reports public or private. Private means that only the scouters’ team will be able to review that report. By making a report public, any team using MorScout will be able to view the report, allowing each FRC team to assist in every team’s scouting.
Although MorScout is currently in heavy development, you can view our progress at our Github pages. Our goal is to finish MorScout by Week 1 of FRC competitions.
Server: https://github.com/mortorqrobotics/morscout-server
Web client: https://github.com/mortorqrobotics/morscout-web
Android: https://github.com/mortorqrobotics/morscout-andorid
iOS: https://github.com/mortorqrobotics/morscout-ios
Last year’s version of MorScout is also available here:
https://github.com/mortorqrobotics/morscout-2015
