Go to Post FIRST is about so much more than what happens on the field, and sometimes we forget that. - Lil' Lavery [more]
Unread 13-01-2016, 13:01
thatismytruck's Avatar
thatismytruck thatismytruck is offline
It can be done
AKA: Skip
thatismytruck is an unknown quantity at this point
Re: Outer Works Defence Sensors
Originally Posted by ABreyen View Post
Hey! I was wondering if anyone knew what kind of sensor is in the Outer Works Sensors. For example, if a robot held open the Sally Port, can two robots go thru, one immediately after each other, making that defense have zero strength? Or would the Sally Port door have to close for it to work?
Basically, how are robots going thru defenses counted? Our thoughts were that that's a lot of counting and details for match personnel to input into FMS.
Thanks!!
Double check me by re-reading the rules, but ...
I believe the door (in this case) can be held open by one robot and the defense weakened with passage by another alliance member. However, the door must be reset (the door must close) and then reopened before another robot can weaken it further.
