Go to Post Someone wake me up the day of Kickoff. - Andrew Schreiber [more]
Unread 13-01-2016, 13:53
KevinG KevinG is offline
Chesapeake LRI/Friendly Giant
AKA: Kevin
FRC #3650 (RoboRaptors)
KevinG is just really niceKevinG is just really niceKevinG is just really niceKevinG is just really nice
Can teams damage their own defenses?
3.1.3 says that "A DEFENSE is CROSSED by a ROBOT when that ROBOT starts free of contact with the DEFENSE and completely in the NEUTRAL ZONE, traverses the DEFENSE such that its BUMPERS go fully between the adjacent SHIELDS/GUARDRAIL, and ends up fully contained by the opponent’s COURTYARD." If a robot from the blue alliance goes from the neutral zone across a blue defense into the blue courtyard, and then later on enters the red courtyard, who gets the points for crossing a defense and is the defense damaged?
As far as I can tell once the blue robot enters the red courtyard the defenses would indeed be considered crossed, the points would go to the blue alliance, and the defense would be damaged. I suspect this is an oversight.
Unread 13-01-2016, 13:57
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: Can teams damage their own defenses?
what i got from it is that it's considered a crossing from the other alliance's perspective, so you'd give them 5 points
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
This would be a good question for the Q&A...
Unread 13-01-2016, 14:00
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
What is presumed in the rule is: Only the last defense contacted by the Robot is considered.
The "Courtyard" part of the rule is to have a bright line to determine how far the robot has to go in order to be considered traversed.
Assuming that your interpretation is correct, you could partially traverse multiple defenses (red and blue), and then once in the courtyard, you get scored on all the defenses.
Note: In the Definition section, the wording is a little better:
CROSS an act performed by a ROBOT, such that it starts free of contact with an opponent DEFENSE ... traverses the DEFENSE ...
The first use of DEFENSE is qualified by "opponent", and the second use is reasonably interpreted as the DEFENSE previously mentioned in the same sentence.
Unread 13-01-2016, 14:23
davidstorer14 davidstorer14 is offline
davidstorer14
FRC #3753 (Bulah Bots)
Team Role: Driver
davidstorer14 is an unknown quantity at this point
Really there wouldn't be a reason to cross your own defenses since you can go through your own secret passage to get past your outer wall.
Unread 13-01-2016, 14:24
Chase Haddleton's Avatar
Chase Haddleton Chase Haddleton is offline
Software Mentor
FRC #3683 (Team D.A.V.E.)
Rookie Year: 2015
Chase Haddleton is an unknown quantity at this point
Might be faster if you're on the other side of the field and you want to go over the "ground level defences" (moat etc)
Unread 13-01-2016, 14:43
bjtheone bjtheone is offline
Design and Fab guy
AKA: Brad Warkentin
FRC #2706 (Merge Conflict)
bjtheone is an unknown quantity at this point
Nope. CROSSING is NEUTRAL ZONE -> DEFENSE -> opponent's COURTYARD.
Any other sequence is not a CROSSING. You cannot "undamage" your defences by crossing them, or generate points for the opposing alliance.
You get points for CROSSING their DEFENSES, they get points for CROSSING yours.
Further, each ROBOT can only score points for one CROSSING and weaken one DEFENSE in AUTO, no matter what further actions they complete in AUTO.
Unread 13-01-2016, 14:44
The "crossings" have to be entered by a Ref.
A "Ref" is NOT going to remember that (let alone look for) you crossing your own defense for possibly entering as a score way later in the game.
The Ref will be looking for a robot currently crossing, and once the crossing is complete, enter the score.
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
More specifically, 3.1.3. outlines the definition of CROSS as 3 individual requirements (bullet points) rather than a sentence. Since all of the wording in the three bullet points is singular, only one CROSSING is awarded per meeting of the bullet points.
For example, if blue cross its own defenses 8 times it has met the requirements of the first two bullets 8 times and the third bullet point is never met (it's not the opponent's courtyard). If it then crossed a red defense once it has met the requirements for the first two bullets 9 times, but the third bullet point has only been met one time, thus is only awarded for one CROSSING.
It's an interesting edge case to think about, for sure.
GitHub
Unread 14-01-2016, 09:56
AKA: Kevin
Hopefully it's an edge case they'll clarify, since I could definitely see there being a reason to cut across your own defense if it's faster (say to pick up a loose boulder or go on defense). As others have said in this thread it puts an undue burden on the refs, but the rules also emphasize that it falls on the team to inform the refs when conditions are met.
I'll try to submit a Q&A once I get the team password. I suspect this is a simple oversight and teams will be allowed to cross their own defenses with impunity, although it would be interesting if they decide not to permit it.
Unread 14-01-2016, 10:28
JesseK's Avatar
FRC #1885 (ILITE)
To me, as a planned ref at a district event, it's pretty clear cut that the robot only met the requirements of CROSSING one time.
GitHub
Unread 14-01-2016, 11:39
Doug Frisk's Avatar
Doug Frisk Doug Frisk is offline
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
While you cannot damage your own defenses, I would suggest that if your strategy involves traversing your own defenses you keep an eye on what the refs are doing the first week or two.
It's quite possible that in the heat of the moment a ref may not notice the bumper color and mistakenly award the opposing team credit for crossing the defense.
If that's the difference between fully breaching the outer defenses or not, it could affect seeding. But at least you'll get to hang out in the question box for a bit.
Or you could use the secret passage to avoid the potential issue.
Unread 14-01-2016, 16:00
Ceering's Avatar
Ceering Ceering is offline
That one guy in the corner
FRC #2960 (Automation Nation)
Ceering is an unknown quantity at this point
Well, even if you could, you can only damage by going into the courtyards (from my understanding), and you have the secret passage.
But I would assume you can't damage them.
Unread 14-01-2016, 16:28
logank013's Avatar
logank013 logank013 is offline
System.out.println("Ready!");
AKA: Logan Kreisher
FRC #0234 (Cyber Blue)
Team Role: Scout
Rookie Year: 2015
logank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant futurelogank013 has a brilliant future
A huge questions shouldn't be about the rules but about the field. How do the LEDs turn off when crossing a defense. Is it done by a referee or is there a sensor on each defense that allows them to recognize when someone crosses it? Thanks. I'm now curious
Cyber Blue Season 2015
IN Indy District Chairman's Award Winner | IN Kokomo District Event Winner (With 135 and 3865)
IN Purdue District Event Winner (With 1024 and 2197) | IN District Championship Winner (With 1024 and 292)
WORLDS:
Archimedes Rank 3 After Quals. | Alliance #3 Captain
Archimedes Division Semi-Finalist (With 503,188, and 836)
Scouting is life. Excel is friend, not foe.
Unread 14-01-2016, 17:12
If you look at the field drawings (not the team version), you will see that there are no sensors.
Look at the box in section 3.1.3, and tell me if you still don't know the answer.
