Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Unread 12-01-2016, 17:26
Pyro_84 Pyro_84 is offline
FRC #1769
Pyro_84 is an unknown quantity at this point
Defenses and Breaching
Me and my coach have had an ongoing debate on whether you can fully damage a defense by yourself.
i.e. I go through the low bar twice and reducing it's health to 0 points, scoring five points both times
Is this possible.
Unread 12-01-2016, 17:30
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: Defenses and Breaching
Yes but as the rules states you have to go from the neutral zone to the enemy courtyard to weaken a defense.
3.1.3 DEFENSES and the OUTER WORKS
The OUTER WORKS impede the passage of ROBOTS and BOULDERS into the COURTYARD. ROBOTS
move BOULDERS across the OUTER WORKS into the COURTYARD one-at-a-time.
Each DEFENSE starts the MATCH with two (2) STRENGTH (a measure of progress towards the
completion of an objective). Each time a DEFENSE is CROSSED by a ROBOT, its STRENGTH is
decreased by one (1). When a DEFENSE’S STRENGTH reaches zero (0), the DEFENSE is DAMAGED.
The STRENGTH of a DEFENSE is indicated by DEFENSE lighting as described in Section 2 (2.2.2.1
DEFENSES). Once four (4) out of an ALLIANCE’S five (5) DEFENSES have been DAMAGED, the
ALLIANCE’S OUTER WORKS are BREACHED.
A DEFENSE is CROSSED by a ROBOT when that ROBOT
■ starts free of contact with the DEFENSE and completely in the NEUTRAL ZONE
■ traverses the DEFENSE such that its BUMPERS go fully between the adjacent SHIELDS/GUARDRAIL,
and
■ ends up fully contained by the opponent’s COURTYARD.
ROBOTS can also receive AUTO points for REACHING a DEFENSE. A DEFENSE is REACHED when,
at the end of the AUTO period, any part of a ROBOT’s BUMPERS are within the opponent’s OUTER
WORKS. Once a ROBOT CROSSES a DEFENSE in AUTO, any additional DEFENSES that ROBOT
REACHES or CROSSES during the AUTO period will not decrease DEFENSE STRENGTH nor contribute
points to the ALLIANCE.
If it is unclear whether a ROBOT has satisfied the requirements for
CROSSING or REACHING a DEFENSE, the REFEREES are instructed
to not award credit. As such, DRIVE TEAMS should make it very clear
that their ROBOT has met the criteria for CROSSING or REACHING a
DEFENSE.
A BREACH of the opposing ALLIANCE’S OUTER WORKS earns the ALLIANCE one (1) Ranking Point
during Qualification MATCHES (see Section 5 (5.3.3 Ranking Score (RS))) or match points during
Playoff MATCHES.
Unread 12-01-2016, 17:31
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Is this possible.
In autonomous, you can't score twice.
In teleop, You can breach all the defenses you want
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 12-01-2016, 17:32
wazateer1 wazateer1 is offline
FRC #3506 (YETI Robotics)
wazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to behold
You cannot damage a defense unless you start completely in the neutral zone, and cross all the way into the courtyard, but there is no rule saying you cannot then back up across the defense and cross it again
Unread 12-01-2016, 17:48
CoreyBrown's Avatar
CoreyBrown CoreyBrown is offline
FRC #1710 (Former Neutrino Mentor, 1710 Alum)
CoreyBrown will become famous soon enoughCoreyBrown will become famous soon enough
I'm slightly confused as to what "Once a ROBOT CROSSES a DEFENSE in AUTO, any additional DEFENSES that ROBOT
points to the ALLIANCE." means. Does that mean you can CROSS the same DEFENSE twice and decrease its STRENGTH and score twice? The use of the word "additional" just hit me funny.
Well, at least the battery ejector works well...
Unread 12-01-2016, 18:35
adam the great's Avatar
adam the great adam the great is offline
Strategy Mentor
AKA: Adam Brewster
FRC #2168 (Aluminum Falcons)
adam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud ofadam the great has much to be proud of
It means that once you fully cross it during auto you no longer can get the 2 pts for ending in the outerworks, nor can you back up and cross through any of the defenses to do damage to it nor get any points from it. (Q & A comes out real soon so be sure to watch that as it will certainly be clarified on there.)
~Adam Brewster~
2168 (Drive Coach/Strategist)
Past Teams: 1930, 2228, 229, 4124, 5240#NeverForget4124
Unread 12-01-2016, 18:40
BrianAtlanta's Avatar
BrianAtlanta BrianAtlanta is offline
FRC #1261
BrianAtlanta has a spectacular aura aboutBrianAtlanta has a spectacular aura about
Let me try to explain with examples.
1. get through a defense and be totally in the courtyard. Score 10pts for crossing, defense takes a point of damage.
2. Get through a defense in to the courtyard (defense takes 1pt of damage), turn around drive over a defense in to the neutral zone. Turn around, drive over the defense and in to the courtyard a second time (defense does not take any damage and you get no points). 10pts
Brian
Unread 12-01-2016, 19:31
DaneeR DaneeR is offline
FRC #2539
DaneeR is an unknown quantity at this point
In Autonomous- no you cannot totally damage a defense on your own because you can only get points for crossing one time.
In Teleop- YES, ABSOLUTELY. You can damage any or all the defenses, getting points for crossing both times.
Unread 13-01-2016, 10:12
coachm's Avatar
coachm coachm is offline
Coach
FRC #3865 (Riley Robotics)
coachm will become famous soon enough
What if 2 robots from the alliance cross the same defense? For example, they take turns crossing the low bar.
3.1.3 says "any additional defenses that robot crosses", which suggests that 2 robots crossing the same defense would count as damaging.
Would take good cooperation to get timing right, though, with little benefit unless both 'bots were only able to cross low bar.
Unread 13-01-2016, 10:14
coachm's Avatar
Coach
As to scoring for crossing defenses, does everyone agree that you can only score points for crossing a defense twice with a maximum of 50 points possible for all 5 defenses? After damaging a defense there are 0 points for crossing any more?
Unread 13-01-2016, 10:27
CoreyBrown's Avatar
This is now clarified in Team Update 1 as "Any additional REACHES or CROSSES by that ROBOT..." It sounds like you and one other alliance partner can damage a defense if you both cross it during the autonomous period.
Unread 13-01-2016, 12:49
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
The point that each defense can only be weakened twice is pretty clear by a combination of 3.1.3 and Table 3-1.
Our general understanding is that auto crossings will also de-strengthen defenses. With this in mind the ideal first three crossings will be in Auto and will count for 10 points each. So best total defense score is 65.
Alan Gilgenbach
C.O.R.E 2062
Unread 13-01-2016, 14:28
Joe Wilson Joe Wilson is offline
Mentor & FRC West Board Member
FRC #4627 (Manning Robotics)
Joe Wilson is an unknown quantity at this point
This does not imply that CROSSING a defense once it's strength is at 0 no longer awards CROSSING points.
That is to say, it does not imply that a DAMAGED defense no longer awards points for additional CROSSINGS.
This will be one for the Q&A for sure.
Unread 13-01-2016, 14:36
bjtheone bjtheone is offline
Design and Fab guy
AKA: Brad Warkentin
FRC #2706 (Merge Robotics)
bjtheone is an unknown quantity at this point
Nope look at the scoring chart on 3.3.1. Points are awarded for CROSSING an UNDAMAGED DEFENSE. Once it has been CROSSED twice it is DAMAGED.
Unread 13-01-2016, 15:03
Ahah! There it is, good catch
