Passing the boulder
I'm sorry if im repeating myself from the other threads but I did not see anything on any rules if we are allowed to pass the boulder to another robot on the same alliance once you breech the outerworks? So basically can you have another robot feed you the boulders as long as they breech the outerworks? Sorry if i am repeating but I could not find anything on this.
Thank you in advance for your help. Bobby Hudock Co-build leader Team 4601 Canfield Circuitbirds |
Re: Passing the boulder
The boulder rules have nothing to do with breaching. The pertinent rules only talk about how boulders may legally enter the opponents courtyard. Once they're in the courtyard, you can do about whatever you want with them, including passing them to a teammate that may have started the match in the opponent's courtyard and never left it. If they anything specific you're confused on with the boulder rules?
You didn't see any rules against it, did you?
I don't see much use for it, because getting a boulder into your robot, while you're on the opposing courtyard, is not a trivial task. It seems to me that it would be more useful to score the boulder in the low goal, than to give up possession.. If your robot is able to pass it to another robot, you could just as easily "pass" it to the goal, eh? Points per unit time.... |
That basically answers our question of once your into the courtyard you can do whatever you want with the boulder. Thank you!
Bobby Hudock Team 4601 Canfield Circuitbirds |
There is a benefit to passing to a bot that can reliably shoot the high goal.
Maybe. Depends on how long it takes them to fetch their next boulder and what defenses they can cross. If it takes you both the same amount of time to fetch and score, then you're probably better off scoring individually, since they won't have to wait for your pass, you won't have to wait for them to shoot, and there's no extra delay for the pass to happen.
#7
Except of course launch them outside the field intentionally. |
#8
Or wedge a DEFENSE open, or damage them, or...
#10
My ideal ideation of a Courtyard Supershooter has more than 1 boulder collector method/entry so single robot defense against it receiving the pass is not going to be quite as effective. When we built our Rebound Rumble Robot, we built in both front and rear collection points and the ability to reverse the feed so we could intake front and rear and operate them independently of each other (but as a stream), and intake rear from 1 robot, expel same balls from the front. We could actually sit in the middle of the auto assembly line and both of us fed our balls straight to a shooter partner who then shot them all center high and nobody moved. |
#11
An in depth look at how you may pass through the outer works without crossing, or violating the rules. Say you have a passing robot and a receiving robot.
The passing robot is partly in the neutral zone and partly in the outer works. The receiving robot is partly in the courtyard, and partly in the outer works. Rule G40 states A ROBOT may not cause a BOULDER to move from the NEUTRAL ZONE into the opponent’s COURTYARD unless... There is no rule about causing a Boulder to move solely from the neutral zone into the outer works. [This is the rule-legal task of the Passing robot] There is also no rule about causing a boulder to move solely from the outer works into the courtyard. [This is the rule-legal task of the Receiving robot] Because the receiving bot manipulates the boulder within the outer works, it is the cause of the boulder entering the opposing courtyard, and thus, the passing bot is not the cause of a BOULDER mov[ing] from the NEUTRAL ZONE into the opponent’s COURTYARD Under these conditions, the pass is in compliance of rule G40. G41 also states that during each CROSSING, a ROBOT may not cause more than one (1) BOULDER to move from the NEUTRAL ZONE into the opponent’s COURTYARD. Because neither robot ever has to cross (you only have to CROSS because of rule G40) , they can pass as many boulders as they want, with no limit. Last edited by AndyBare : 13-01-2016 at 18:37. |
#12
Andy, I'd ask Q&A about that one. Occasionally, the letter and the spirit of the rules aren't on speaking terms. This appears to be one of those cases.
#13
In general, is it illegal for a robot to pick up a boulder from the OUTER WORKS from the COURTYARD's side, therefore not qualifying as a valid CROSSING? For example, a stray boulder gets stuck in the ROUGH TERRAIN, or perhaps more contentiously, a bowl from the human player to (through) the LOW BAR? |
#14
You can also pass a boulder from the Outworks (that you got from the Neutral Zone) as long as you end up in the courtyard. There is no rule that requires you to hold onto the boulder until you reach the courtyard. Only that, if the boulder ends up in the courtyard, the robot must also eventually end up in the courtyard (with our without the boulder).
